Aluminum sprockets
- tobiism
Aluminum sprockets
23 Feb 2007 18:41
Does anyone know if there are aluminum secondary drive sprockets available for my 750 twin? I need a 17 and a 38 tooth. TIA, Matt
- 77KZ650
Re: Aluminum sprockets
23 Feb 2007 19:14
not sure if the 750 sprockets will swap with 650 sprockets, but I have a 02zx7 rear sprocket that will bolt up to a 650 rear wheel, the "hole" in the center is a bit bigger, but the bolt pattern is the same
07 MDP Rookie of the Year
- arobsum
- tobiism
23 Feb 2007 20:16
arobsum wrote:
They actually work pretty well as long as they are kept lubed, cleaned and at the proper tension.
just how long would an alum. sprocket last?
- 77KZ650
23 Feb 2007 20:20
Im going to make a guess and say half as many miles as steel ones. but they are light as a feather, and the plus side to it is its not just taking weight off of the bike, its taking off rotating weight. which means better acceleration. I think I read somewhere that taking off 1 pound of rotating weight = taking off 7 pounds of "regular" (not moving ex: extra metal tabs) weight
- steell
24 Feb 2007 06:21
You have mag wheels on that 750 twin?
My reason for asking that is that I have discovered that steel sprockets are not available for the Morris Mags that were a dealer installed option for the 76-79 twins. I had to get an aluminum rear sprocket from Sprocket Specialist as no one makes a steel rear for them. I had 17/38 on my last 79 with Morris mags, my new set has a 37 on the rear and I'm going with a 17 front.
One of the PM wheels uses the same sprocket, but I forget which one. Pay the extra $$ for the coating, makes the sprocket last longer.
Post edited by: steell, at: 2007/02/24 09:25
- tobiism
24 Feb 2007 08:39
steell wrote:
Nah, I've got spokes. Thanks for the info though.
One of the PM wheels uses the same sprocket, but I forget which one. Pay the extra $$ for the coating, makes the sprocket last longer.<br><br>Post edited by: steell, at: 2007/02/24 09:25
