leaky valves
- atp
leaky valves
22 Feb 2007 11:57
I have a 1977 kz 650. I'm swapping a top end off another kz650 engine. I was wondering if their is a way to test the valve seals while I have the head off. Any help greatly appreciated. Thanks-alex
- wireman
Re: leaky valves
22 Feb 2007 12:27
lay the head on its front or back with ports on a flat surface.now fill the ports that are pointing up with solvent take an air hose with a blower on it and blow air around the edge of valves and seats where they meet.look for bubbles in the solvent in the ports then flip head over and repeat.this isnt 100%,but it will give you an idea what you have to work with
- atp
Re: leaky valves
22 Feb 2007 13:02
I'm wondering if oil from the stem is leaking down. I tested the valve seat and they seem good, but am wondering if the valve stem seals are worn.
- atp
Re: leaky valves
22 Feb 2007 13:03
I know the valves are seating, but was wondering about the valve seal. Would removing buckets and pouring solvent on top valves work?
- wireman
Re: leaky valves
22 Feb 2007 13:15
ah,my bad!
if you are that far into it id pull the springs and throw some seals on it,and check guides at same time;)
- atp
Re: leaky valves
22 Feb 2007 14:54
Thanks, thats what i will do for peace of mind. Do you know where i can order the seals? And how do you check the guides?-thanks
- wireman
Re: leaky valves
22 Feb 2007 17:01
let me find my Z! enterprises stamp,oh here it is!
take the valves and see if they rock in the guides;)
