Replacing valve cover gasket
  • geerbangr
  • geerbangr's Avatar Topic Author
21 Feb 2007 15:09
#114233
My valve cover gasket is leaking , i've bought a new gasket from the kaw garage . The gasket has sealer type material placed all over it . Is it necessary to use any black rtv when installing oem gasket ??
1978 KZ 1000
I go by Jason
  • RonKZ650
  • RonKZ650's Avatar
Re: Replacing valve cover gasket
21 Feb 2007 15:23
#114238
If you clean the mating surfaces of any old gasket material, then no sealer is needed. This goes for pretty much any gasket on our KZs.
  • loudhvx
  • loudhvx's Avatar
21 Feb 2007 20:13
#114308
As a matter of fact, I even go further and apply a thin layer of anti-sieze on the gasket. Then it comes off in one piece with no scraping later on. (I don't reuse the gasket, I just do it because i hate scraping.) The key is that the surfaces have to be absolutely clean and smooth then they won't leak. I usually use a tiny dab of sealant only on the cam end-caps.
Post edited by: loudhvx, at: 2007/02/21 23:15
  • wireman
  • wireman's Avatar
21 Feb 2007 22:26
#114340
loudhvx wrote:
As a matter of fact, I even go further and apply a thin layer of anti-sieze on the gasket. Then it comes off in one piece with no scraping later on. (I don't reuse the gasket, I just do it because i hate scraping.) The key is that the surfaces have to be absolutely clean and smooth then they won't leak. I usually use a tiny dab of sealant only on the cam end-caps.<br><br>Post edited by: loudhvx, at: 2007/02/21 23:15
chapstick works good on carb gaskets to keep them from sticking;)
  • Fourtoes
  • Fourtoes's Avatar
22 Feb 2007 01:43
#114345
So does anyone know an easy way to get OLD gaskets off? Apart from scraping for hours and hours and hours!
Its taking forever:(
22 Feb 2007 02:36
#114348
Might try Permatex Gasket Remover
