Anyone know if the 82 1100 Spectre Head is the same as the GPz Head?
  • otakar
  • otakar's Avatar Topic Author
21 Feb 2007 15:08
#114232
The title asks the entyre question. I know there are some diferrences in the "j" series 1000 and 1100 heads, and that there were three diferrent cams used in these bikes, but that is about all.
Otto Kudrna
Post edited by: otakar, at: 2007/02/21 18:10
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: Anyone know if the 82 1100 Spectre Head is the same as the GPz Head?
21 Feb 2007 15:44
#114242
gpz1100 has fuel injection inlets on the b1,
well mine has.
Post edited by: kano, at: 2007/02/22 09:18
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
22 Feb 2007 05:44
#114372
Otto:
The B2 model does not have the FI ports in the head, BUT, the heads of the 1982 Spectre and 1982 GPz do have different parts numbers, suggesting a difference, which may or may not be trivial.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • kano
  • kano's Avatar
22 Feb 2007 06:33
#114381
hopfully this will help.
yes i have to much time on my hands.
Post edited by: kano, at: 2007/02/22 09:34
  • joskin
  • joskin's Avatar
09 Mar 2007 17:14
#118786
a couple of subtle difference's ive noted on gpz 11 heads in the past, in particular 1100a1 and a2 motors run with under bucket shims (the small ones) as oppossed to older 1100s which have the larger over bucket items. also if you go for the later type a1 or a2 cylinders and heads these do not use o ring oil seals on the outer 4 studs, so pay extra care to gasket installation or you may find your newly assembled ride has aquired a very effective leg and boot lubrication system :dry: :)
