---- topicz topicsz ztopicZ
- H1Vindicator
Last edit: 21 Feb 2013 11:14 by H1Vindicator.
- neilage66
Re: Engine oi level and the meniscus
19 Feb 2007 07:15
Don't hear the word "meniscus" around here too often.
Short answer...iffn your level (at the base of meniscus) is between the lines, you (and your motor) are ok.
If you lose sight of the oil (too low) or the meniscus (too high) check closely to see where you're at and adjust accordingly.
If you fill the oil till the meniscus just disappears above the sight glass it is not a problem, maybe just a wee bit of blowby.
Take care, and mind the meniscus! :laugh:
- H1Vindicator
Last edit: 21 Feb 2013 11:15 by H1Vindicator.
- KaZooCruiser
19 Feb 2007 07:36
You probably know to check the level with the bike standing level (not on the side stand or centerstand).
Iffen you didn't know that, now you do. . .:laugh:
- H1Vindicator
