cheap valve spring compressor
  • mountain
  • mountain's Avatar Topic Author
  • go with the flow
15 Feb 2007 13:02
#112642
Take a 3/4" rigid steel pipe and cut with a sawzall (carefully) the little jig in the attached picture. Then, any 5 or 6 inch c-clamp can push this down over the valve washer and you can pull out the split keepers through the "window". Vlave compressors cost way too much.
1977 KZ 650 B1, I own two of them. Working on one custom rebuild, one daily rider. Used to have a third. Two 1978 KZ 650 C2 models, sold both. KZ owner since 1987.
  • mountain
  • go with the flow
Re: cheap valve spring compressor
15 Feb 2007 13:04
#112643
oops, I'm still trying to get the hang of posting pictures.
  • KaZooCruiser
  • KaZooCruiser's Avatar
15 Feb 2007 13:19
#112646
Interesting approach. . .
seems you can do the same thing with one of these
Post edited by: KaZooCruiser, at: 2007/02/15 16:50
  • 77KZ650
  • 77KZ650's Avatar
15 Feb 2007 21:08
#112785
I made my own too, theres a "how to" in the filebase. great to see another DIY guy
07 MDP Rookie of the Year
