650 to 750 exhaust?
  • Draco
  • Draco's Avatar Topic Author
650 to 750 exhaust?
14 Feb 2007 09:39
#112329
would a set of Jardine 4-2 headers for a 78 KZ650 B2 fit on a 80 KZ750E? Each header pipe is separate, and connect to the turn out mufflers. Probably a long shot, I know.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: 650 to 750 exhaust?
14 Feb 2007 09:56
#112333
The exhaust port openings are the same.
The most you will probably have to deal with is where/how the individual mufflers will mount at the rear of the bike.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Draco
Re: 650 to 750 exhaust? PIC
14 Feb 2007 10:00
#112335
making/modifying where the mufflers mount isn't a big deal, as I have access to a plasma cutter and welder.
My main concern was the exhaust port size and the routing of the pipes. they are the crossover design, so I am wondering about frame clearance, etc.
1-4 out right side, and 2-3 out left.
Thanks for the info so far R4!
Post edited by: Draco, at: 2007/02/14 13:10
Post edited by: Draco, at: 2007/02/14 13:12
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
14 Feb 2007 10:31 - 20 Feb 2013 18:27
#112350
Last edit: 20 Feb 2013 18:27 by H1Vindicator.
  • Draco
14 Feb 2007 10:41
#112354
are the 650 and 750 frames, centerstand location that similar? Pics of your situation couldn't hurt, Thanks.
  • H1Vindicator
Re: ----
14 Feb 2007 10:45 - 20 Feb 2013 18:29
#112355
Last edit: 20 Feb 2013 18:29 by H1Vindicator.
  • Draco
14 Feb 2007 11:06
#112360
I'm wondering about the frame from a 78' 650 matching mine. If the frame from a 78 is the same as your's, then I think everything would fit, especially if a 750E set would fit on your 650. may have to fab some new brackets, but that;s easy enough.
  • H1Vindicator
Re: ----
14 Feb 2007 11:34 - 20 Feb 2013 18:27
#112365
  • Draco
14 Feb 2007 12:09
#112372
If the center stand recess is all that would cause a problem, I'd just lose the centerstand all together;)
It's far from stock at this point anyway. The only hesitation is that I'd have to buy the set up, wait for them to get shipped here, then mock them up to see if they'd work or not. That's a bit of a risk that I'm trying to find justification to take.:S
Thanks for all the info thusfar!
  • 77KZ650
  • 77KZ650's Avatar
14 Feb 2007 22:46
#112510
my MAC 4-1 fits kz650, kz750(four) and gpz750. it didnt say anything about yrs, so I guess all
07 MDP Rookie of the Year
