1075 build
- brianrae33
1075 build
12 Feb 2007 07:14
quick question..boring to a 1075, upgrading to 28mm z1r carbs, not splitting the cases..been reading alot about getting the crank welded..plan on an occassional run at the local 1/8 mile track..how much should i be worrying about my crank slipping??
1982 kz1000ltd
- Z1109R Fin
Re: 1075 build
12 Feb 2007 08:40
I wouldn´t worry about crank welding. 1075 Wiseco + upgrading carbs gives you max 20rwhp increase and what I´ve heard/read welding becomes necessary after 130-140hp. I´d also like to hear if someone has had problem on crankshaft ´cause I got 1109cc, Mikuni flatslides, ported intake etc...
Z1000R ´83...Slightly modified...
- trippivot
Re: 1075 build
12 Feb 2007 08:53
slipping or twisting is a issue but you are not doing redline standing start launches all the time are you?
however a welded crank is a must if you are launching with a 2 step, slider clutch and a slick tire. that is what really hits the crank.
I payed 75.00 to get mine welded up here in the quad cities. tough part is splitting the cases. the money and effort is better spent on bigger valves better carbs or updating the lighting/charging system.
I did mine but it is a matter of what you want to spend and how much you like to work on the engine. while you are there a better camchain is advised and clearance the cases for bigger bore pistons do a competition trans cutting procedure,etc... once it is split the choices begin to arise
- wireman
Re: 1075 build
12 Feb 2007 16:33
Z1109R Fin wrote:
im not sure if there is a hp cutoff point where it becomes a definate must,but if there was id say its well below 130-140 hp!like trippivot said its more of a matter of the bike hooking up hard and twisting the crank than anything else.if you dont hammer it really hard on a regular basis its probably overkill,but if you are letting some air out of your back tire and running at the track or "sidestepping" the clutch:evil: it would be a cheap insurance policy and would be a good excuse to check the rest of your bottem end so you are covered for whatever you throw at it.and yes a timing chain is a good idea;)
- larrycavan
- wireman
Re: 1075 build
12 Feb 2007 17:35
larrycavan wrote:
i like this guy!I agree with everything Wireman saidB)
- arobsum
Re: 1075 build
12 Feb 2007 19:06
my 900 has a 1075 kit (with vm28's) and was made for the drag strip. it even has aftermarket cams. the P/O didn't weld the crank and it works just fine.
