Why are my pistons black?
- nads.com
- larrycavan
Re: Why are my pistons black?
13 Feb 2007 12:18
Look at your intake valves and see if there's a lot of buildup on the back sides. If there is, pull he head apart and clean it off. If it looks like it's from oil, you may need guides / seals.
kztee wrote:
kztee wrote:
So, I have finally started to disassemble my 1K. I will probably end up going with the 1075 pistons regardless of the cylinder condition (if steell can still get me a number for the place that has the kit). But I got the head off and noticed the tops of all four pistons are charred black. The spark plugs look pretty black as well. I really dont have very many miles on this since it was last taken apart and probably only a couple hundred or less on the plugs. What would cause this?
Also, my parts bike has a valve cover with air suction covers. What do these do? Would it be worth my while to use this valve cover instead of the stock one?
I will try to have pics in a little bit. Need to resize them.
kzrider.com/media/kunena/attachments/leg...07_0211Image0011.JPG [/img]<br><br>Post edited by: kztee, at: 2007/02/11 22:25
