Cam chain timing
- Ag3NT
Cam chain timing
11 Feb 2007 08:54
I had a long thread started in the Carb section, but it has evolved. The problem is my KZ750 M1, it will not start. I have spark and fuel, but no compression. I have no manual. I need to check the CAM timing to rule that out before moving on to valves and rings/pistons. Does anyone have a manual that they could maybe copy a few pages or walk me through the process of the timing?
Thanks,
Post edited by: Ag3NT, at: 2007/02/11 21:03
Thanks,
- Ag3NT
- OKC_Kent
Re: Cam chain timing
12 Feb 2007 12:56
I hope steell and biquetoast can help you. They own a couple of the big twins and should have a manual to help you.
Cashion, OK
78 KZ650 B2 85,000+ miles
- OKC_Kent
12 Feb 2007 13:04
Cashion, OK
- Ag3NT
19 Feb 2007 21:23
I finally got a service manual from Kawasaki. I have the cam timing as close as it looks like it will get. The intake side is lined up great. The exhaust side is off by about half a link. It really looks like the chain jumped a link (the tensioner needed to be adjusted also). Is it possible for this to cause the severe lack of compression? The manual says it should be 156psi and it was only holding 30psi.
Thank you,
Thank you,
