KZ440 wont go
  • DeftoneKZ440
  • DeftoneKZ440's Avatar Topic Author
KZ440 wont go
30 Nov 2005 13:37
#11111
1980 KZ440 A model.Ive been having a frustrating time trying to figure out this problem so now i'm turning to you guys to please help me, hopefully one of you on here had a similar problem and solved it.
Heres what happened, my clutch cable sometimes would need to be adjusted so when I shift I dont get the dragging and eventually the cable just started to get more and more loose. So I ordered a new cable, motion pro, and installed it. I installed it correctly, routed it good, there were no kinks or sharp bends, and it the adjuster on the cable was tighted so the clutch lever started to feel stiff like there was a clutch. when I started the bike up its in neutral, I shift down into first gear to go foward but the bike wouldnt go. The egine would just rev when I accelerate but not move forward. Even if i relase the clutch lever in first gear the bike would not stall out it'll just stay on but the neutral light is turned off. I know the bike is in first gear because it you can hear the noise when if shift. I put back in the old cable and the same exact thing happened, it wont go foward. Please help me I dont know what else to do.
  • ltdrider
  • ltdrider's Avatar
Re: KZ440 wont go
30 Nov 2005 14:25
#11115
If your bike is like mine, then the clutch play can be adjusted by removing the eliptical plate on the left side of the engine. See the photo.
Under that cover is a threaded rod with a slot in the end for a flat-tip screwdriver. It is held with a jam nut so it doesnt turn, once adjusted.
Sorry if you already know all this.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • DeftoneKZ440
Re: KZ440 wont go
30 Nov 2005 14:36
#11117
hey thanks for your advice, but I already did adjusted that screw you were talking about and it didnt really help. I dont know what else to do
  • jasbarsydvic
  • jasbarsydvic's Avatar
Re: KZ440 wont go
30 Nov 2005 14:44
#11120
Do you have any free play in the clucth lever?
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: KZ440 wont go
30 Nov 2005 17:37
#11145
Yeah, you have to have a little, like a 1/4 " play. It sounds to me like you have it so the clutch is permanently engages because the cable's too tight.
Just for giggles, try leaving the cable totally loose to see if the clutch "catches"...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • JR
  • JR's Avatar
Re: KZ440 wont go
30 Nov 2005 19:00
#11160
If you go here to Ibsens site www.kz400.com/TechnicaltipsFrameset.html and scroll about 2/3rd of the way down theres a secton on clutch adjustment. The last time I messed with the cable on my 750 I think I had to repeat the adjustment about 6 times before getting it right - very frustrating. Also wonder if it might be worth your while checking out the mechanism on the other side of the adjuster screw location shown in ltdrider's photo and seeing if your mechanism is acting correctly on the clutch pushrod - assuming you have one.
Woodstock ON Canada
1980 kz750 E1, 4->1, K&N pods
  • DeftoneKZ440
Re: KZ440 wont go
01 Dec 2005 19:10
#11347
Thanks for your advice guys, I was working on the bike today and did what some of you said, but I cant test it yet. Back a while ago I removed the clutch cover to inspect the clutch plates and the gasket around that whole cover is deteriorated and oil has been leaking through. Can anyone tell me where I can purchase that gasket online, besides going to the dealer.
  • ibsen22000
  • ibsen22000's Avatar
Re: KZ440 wont go
02 Dec 2005 07:27
#11419
Single gasket:
www.cyclewareables.com/pages/street_moto...l/kawindivgasket.htm
Gasket# CW643-4025 $8
Complete gasket kit:
www.z1enterprises.com/detail.aspx?ID=1861
$27.01
Post edited by: ibsen22000, at: 2005/12/02 10:29
  • TwoSeven
  • TwoSeven's Avatar
Re: KZ440 wont go
10 Dec 2005 19:06
#12561
I'm having the same problem with my tractor :)
I suspect that its a mixture of stretched clutch cable causing exessive clutch plate wear.
I have to pull the lever almost back to the bars before the clutch disengages, and there is no more adjustment left down at the clutch.
I seem to remember that until the cable started going, the clutch was fine, now, today when I was on some hills I noticed a hint of slip.
Being a poor student at the moment, I cant afford to take the clutch cover off and measure everything up - so will just see what effect replacing the clutch cable has.
