Oh my God....One of the cylinder is not working.....
  • Toge
  • Toge's Avatar Topic Author
07 Feb 2007 10:20
#110788
Last night, I found out one of the cylinder is not working. I sprayed some water on the exhaust and the left one didn't have steam come out. My bike has some carbu. problems. Is there any possibility that the left one cylinder cannot suck gasoline from the carbu.?
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
Re: Oh my God....One of the cylinder is not working.....
07 Feb 2007 11:09
#110791
Yes.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • OKC_Kent
  • OKC_Kent's Avatar
07 Feb 2007 11:54
#110797
Have you checked the spark plug? If it is dry after the engine runs then you know the problem is the carb.
If the plug is wet, then the problem may be the plug or plug wires.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • ltdrider
  • ltdrider's Avatar
07 Feb 2007 12:02
#110801
Did it just stop working? Were you firing on all 4 the last time you checked?
Take the plug out, and check your compression. Do the test with your throttle open. You should get somewhere between 115 and 145 psi. I think it'll run at 100 psi.
If compression's OK, check for spark. You may just have a bad plug or plug wire.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
07 Feb 2007 13:06 - 21 Feb 2013 21:13
#110813
Last edit: 21 Feb 2013 21:13 by H1Vindicator.
  • Toge
07 Feb 2007 13:46
#110827
Sir, the plug is black and dry. Plus, I switch with another spark plug and only the left one is not working. what is the caburettor spray for? what parts of carburettor can it clean up?
Thank you.
  • Toge
07 Feb 2007 13:48
#110830
compression? How can I check it? What tool do I need?
  • ltdrider
  • ltdrider's Avatar
07 Feb 2007 14:06
#110835
The coil that fires your left (No. 1) cylinder, also fires your right (No. 4) cylinder. Swap the No. 1 and No. 4 wires, and see if the problem moves to your right cylinder. If it does, then you probably have a bad plug wire. If No. 1 is still cold during this test, then the problem is at the No. 1 plug or cylinder.
If you want to check your compression:
You need to use a compression test gage to test your cylinder compression.
It's a pressure gage with a special rubber piece on the stem of the gage. It's made to fit over the sparkplug hole when the spark plug is removed.
You'll have to borrow one from a friend (if he has one, he'll know how to use it and can help you), or buy one from an auto parts store.
Disconnect ALL of the plug wires. Make sure they're labeled, so you can put them back on the right plugs.
Remove the left side (No. 1) plug.
While holding the gage in the spark plug hole, and making sure you have a good seal, open the throttle, and crank the bike's starter. Air from the cylinder will pump up the pressure gage. The gage is made to stop at the highest pressure measured, so you don't have to be looking at it while you crank.
Read the pressure.
If you've gone this far, you might as well take a reading on the other three cylinders. The should all be above 100 psi, and they shouldn't vary more than about 15 psi from each other.
Greensboro, NC
