Rings
- mark1122
- Keep twisting it
Rings
06 Feb 2007 05:59
Anyone know where I can get 74mm.rings for a 1135cc piston kit.I have a 76 kz 900 that sat in my barn for 22years. I got it running this summer.Now I have it apart tring to improve lost performance.The rings are not sealing properly but clearances are good(.0015").This motor had about 3500 miles on it after new pistons and rebuild,22 years ago.Now the problem is It has a 1135cc Wiesco kit,but wiesco says the pistons were likely bought as blanks by R.C. engineering and RC suplyed the rings and machined the grooves to fit.So wisco's rings are too thin too fit, and RC doesnt supply them any more and doesnt have any info on them.RC likely just bought stock rings from another aplication.So this is where you guys come in.
Does anyone know what bikes had a 74mm bore,pre 1979?Then I may be able to figure out which 1 has the right thickness rings.
My rings are:top .062" (1.57mm),second= .061"(1.55mm.),OIL .107"(2.72mm)Wiesco's are .031(.8mm), or .039"(1.mm) thick.
Also what should the ring to groove clearance be for a street rider, min.max.?
I know the easy answer is buy new 75 mm. pistons and re bore but I just cant afford that extra$1000 with all the things I need for this bike.Thanks for your help.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzwolfsr
Re: Rings
06 Feb 2007 20:33
Don't worry about not getting an answer, not much people have really ran across such a predicament in life like yours, its rare. Hopefully RRRR will help you out or someone with more mechanical experience with this stuff will find you after this post.
Original man of the Caribbean
- BSKZ650
Re: Rings
07 Feb 2007 04:32
there is a company that can custom build rings, I cant remember the name right now,I did some research while looking for std rings. the bad thing is they are going to be expensive
77 ltd1000, current rider
76 kz900, just waiting
- mark1122
- Keep twisting it
Re: Rings
07 Feb 2007 05:56
Total Seal makes rings but they make 500 at a time for only $800.I found the top ring and oil ring at Hastings rings,but no #2 yet.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
Re: Rings
07 Feb 2007 22:32
Did you ask this over on dragbike.com? I answered it over there. Honda 1600cc Civic.
Jay
Jay
- mark1122
- Keep twisting it
Re: Rings
07 Feb 2007 22:43
yes .Thanks. Still no 2nd ring.Is it normal to use a compresion ring in #1 & #2 groove?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Duck
- e vica na i sau na ga
Re: Rings
07 Feb 2007 23:21
these are pretty wide rings
have you looked at older automobile?
hillman, morris, datsun, renault, simca, singer, sunbeam, ???
Post edited by: Duck, at: 2007/02/08 02:22
- mark1122
- Keep twisting it
Re: Rings
08 Feb 2007 01:21
No I just looked at the cataloges for 74mm.and it shows all available in that size.This was at Hastings and Total seal.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
