Help!Part of valve shim tool dropped into cam chain channel
- jeffreygp
05 Feb 2007 06:52
Hello, I need help in getting out part of the valve shim tool that broke off and went down into the gap or channel of the cam chain(beside the intake sprocket). Heard it clink when it hit bottom. I already opened the oil pan and it isn't there.What would be the best and easiest way to get it out. Any help would greatly be appreciated. Thank you.
- Mcdroid
- Gone Kwackers
Re: Help!Part of valve shim tool dropped into cam chain channel
05 Feb 2007 07:06
Get an automotive magnet (swivel magnet on an aluminum rod...sold at autoparts stores) and a good flashlight and take your time and hope for the best...if, not then you start disassembling your motor from the top down until you can fish it out.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- donthekawguy
05 Feb 2007 08:13
You could try rotating the motor by hand (wrench on the points end of the crank) and hope it fell on the crank. If you do it be VERY carefull and if you feel it lock up back it off and you have found your chunk.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- trippivot
05 Feb 2007 08:27
prevention comes with experience. a shop towel in the camchain galley is invaluable.
patience patience patience
the magnet is the tool of choice
shaking it upsidedown is difficult and messy but if you have a friend willing to help you turn the bike over your piece will shake loose eventually
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
05 Feb 2007 09:59
Yep, get a shop magnet. That thing saved my butt a couple times. Luckily, the items that fell in were metalic, and I was able to retrieve them with the magnet.
West Linn, OR
- larrycavan
05 Feb 2007 16:06
I really wouldn't turn the motor over with that piece in there. If it didn't come out in the pan and if you can't find it with a magnet, pull the motor and turn it upside down.
I had a set of Andrews cams that were improperly drilled one time. A pice of the sprocket boss broke off. I noticed it when I did the first valve adjustment after the motor rebuild. Same deal as you, pulled the pan and it wasn't in there. I pulled the motor, turned it upside down and the piece fell right out.
- kano
- Not Another Bloody Limey!
05 Feb 2007 16:34Please Log in or Create an account to join the conversation.
