Broken Output Shaft !
- sbodi4d
04 Feb 2007 19:52
I was removing the engine from my 1980 KZ1000 Shaft, and when I pulled the front bevel drive I found the output shaft broken where the nut is, on the end. How big of a problem is this to replace? I wasn't planning on tearing the engine and tranny down completely, but I may have to now. I took a couple of pics of it.
Hope this works.
Post edited by: sbodi4d, at: 2007/02/04 22:52
Post edited by: sbodi4d, at: 2007/02/04 22:54
Hope this works.
- sbodi4d
Re: Broken Output Shaft !
04 Feb 2007 19:54Please Log in or Create an account to join the conversation.
- wiredgeorge
05 Feb 2007 04:44
You will need to split the cases and replace the output shaft with a new one.
- donthekawguy
05 Feb 2007 08:15
Bummer. But look at the bright side-now you can have the crank welded and put a 1075 kit on!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- larrycavan
05 Feb 2007 16:35
donthekawguy wrote:
Optimism is a powerful characteristic that tends to turn bad situations into good ones!...now where the hell is the thumbs up emoticon?
- hwms
05 Feb 2007 17:36
If it were mine I would drill and tap the shaft and use a cap screw and lock plate.
- steell
05 Feb 2007 18:33
If you could drill a straight hole in that hardened shaft by hand (without using a mag drill) you are a better man than I
- hwms
06 Feb 2007 09:56
Are you sure that the center of the shaft is hardened and not just some depth into the surface?
- nads.com
06 Feb 2007 10:07
Steel what the heck is a mag drill? Magnificent? And why do people think every hole has to be straigh? Can't it be a little crooked since it's just a cap plate? In other words "Without a ten ton Megatron laser you don't have a chance other than suicide, if it's the least bit crooked the earth is gonna shake trees are gonna fall on your garage.
- steell
06 Feb 2007 10:22
Mag drill has a magnetic holder on the chuck end, it locks the drill in place. The cheaper ones are near $500, but the good ones that are programmable are well over $1000.00
I suspect the shaft is hardened all the way through and not just case hardened, but I have not checked to see if it is.
It's not that big a deal to just replace the shaft, so that's what I'd do.
- wiredgeorge
07 Feb 2007 07:09
I don't know if the output shaft is hardened or not. I would replace it. It ain't that big a deal. Cases need to be split. Replace cam chain. A couple hours labor mostly in chasing out the thread in the case bolt holes and cleaning the thread on the bolts and cleaning gasket mating surfaces.
- sbodi4d
07 Feb 2007 12:01
Thanks for all the replies, I don't know that I would trust myself to drill and tap the old shaft, so I will replace the shaft.
George, what do you mean chasing the thread in the case bolt holes? I mean I know what you're talking about, but is there a thread locking agent in there or something?
