J model trans vs. shaft drive
- jasbarsydvic
29 Nov 2005 18:59
Does the shaft drive trans have the same gear ratios as the J model? If they are, can you take the gears from a shaft drive trans, remove them from there shafts and put them onto the older Z1/Kz trans shafts?
The reason i ask is i want the J model trans because the gear ratio's are higher than the older Z1/Kz trans. Meaning less rpms at highway speeds. Any help would be great.
- Trav
Re: J model trans vs. shaft drive
29 Nov 2005 19:36
I'm not sure about gearing and all that, but wouldn't it be more practical (unless you already have your trans apart) to just swap out sprockets to change your gearing? I can't imagine the changes with internal gearing are that drastic.. unless you only want a slight change that would be less than dropping or adding a tooth.
That being said, I think the gears would work, but are the different ratios? No clue.
ps- where can I see a bigger resolution pic of your avatar image? :whistle:
- jasbarsydvic
30 Nov 2005 14:37
My case will be split soon. Going to rebuild the entire motor. Sorry that's all the eye candy that i can give. LOL
