My bike is alive again, but I heard a strange sound....
  • Toge
  • Toge's Avatar Topic Author
31 Jan 2007 19:15
#109452
When I start my engine, I could hear some metal cranking sounds from my engine, but when I press the clutch a little bit, the sound is gone. I guess that is the clutch problem right?
Thank you
:laugh:
  • kzwolfsr
  • kzwolfsr's Avatar
Re: My bike is alive again, but I heard a strange sound....
01 Feb 2007 11:23
#109527
Beats me! Have you ridden it to see if the noise is heard during riding?
Original man of the Caribbean
  • Toge
01 Feb 2007 12:39
#109540
when I ride it everything is fine, the strange sound is only when I shift to neutral. Thank you for your respond.
01 Feb 2007 17:01
#109583
Has the clutch push rod been properly adjusted? :)
  • Toge
02 Feb 2007 07:08
#109695
Not yet, but I am going to do.
  • kzwolfsr
  • kzwolfsr's Avatar
05 Feb 2007 11:47
#110382
Have you changed your oil recently? I would do that and do that pushrod adjustment.
  • Toge
05 Feb 2007 17:53
#110448
yah, I did changed my oil. My bike is freaking right now. When I start the engine, RPM was only around 1500RPM with chock on. I checked my battery. It's kind of low because I couldn't start my engine with starter. I push some gas, it comes backfire with black smoke. I guess it's carbu. problems.
How do you think about this situation? LOW RPM, BACKFIRE,BLACK SMOKE, AND UNSTABLE ENGINE MOVEMENT.
THANK YOU
  • kzwolfsr
  • kzwolfsr's Avatar
06 Feb 2007 06:32
#110528
Definately sounds like the carb is leaning out your fuel intake, wait no, If you have black smoke your air/ fuel mix is rich. I would advise you to clean your air filter.
  • Toge
06 Feb 2007 14:37
#110626
My air filter is new, but it smell like gasoline...
So do I still need to clean up the air-filter?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
06 Feb 2007 16:04
#110639
No, replace it with a new one.
If it smells that badly of gas, it sounds like one or more of your carbs is overflowing and dumping fuel into the airbox and flooding the filter. And if it soaked the air filter, it probably has also dumped down through the crankcase vent tube into the engine. Remove the oil fill cap and see if it smells of fuel in there BEFORE riding your bike again. Then figure out why the carbs are overflowing.
And if your bike backfires through the carbs, your fuel-soaked air filter (and your butt) could possibly become engulfed in flames....not a pleasant thought/experience! :pinch:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Toge
06 Feb 2007 16:31
#110651
Yes, I will replace a new air filter. Just now, I find out my right side of cylinder is working. And then, I changed to new spark plugs, but it still doesn't work. I think because of that my rpm was so low.....
Could you direct me what should I do if one of the cylinder is not working. Thank you.
