Engine Forum
Engine forum is a tech forum for "Engine" topics.
degreeing cams 750
  • jimmybon
  • jimmybon's Avatar Topic Author
Re: degreeing cams 750
01 Feb 2007 13:00
#109544
yeah, I've put the sprockets in the lathe and turned the face down to the depth of the bolt head rebates ( using centre punch to mark the timing marks first)then using a rat tail file elongated the std holes
I rebuilt last night and have now got the right numbers 105 on both cams. I'm looking forward to running the engine as i'm booked for a dyno run next week to fine tune the carbs
I,m riding to Philip Is for the World Super Bikes in 4 weeks, 2500km round trip, that should be a good tester for the engine mods
GPzepher, can i ask wat make gear box you have Re 6 speed?
cheers
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • GPzephyr
  • GPzephyr's Avatar
01 Feb 2007 15:58
#109573
6 speed! Well its basically using a 550 gear set, selectors and transmission cover. It all pretty much bolts straight in.
The 550 cover is needed to put the neutral switch in the right place for the selectors. The cover is not an exact fit, it leaves a small gap at the top, but it hasn't proved a problem as the gasket is wide enough to bridge the gap.
The only other thing is that the output sprocket is held on by a different method. But again nothing too serious.
Well worth doing.
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
  • modprod
  • modprod's Avatar
01 Feb 2007 20:34
#109634
jimmybon wrote:
I am at present trying to check the cam degrees on my z650 hybrid
make up-
gpz750 bottom end
zepher zr750 head and barrels
810 pistons
gpz750r1 82 ex cams
gpz750r1 82 or zepher in cam (not shaw, may have got them mixed up but both have the same lobe size 63.3
I'm using the Doug Meyer method of calcuating the lobe centre at 1mm lift. So standard is 60+30+180/2-30=105, and have found @1mm lift the inlet cam at 4* open, 42* close. So 4+42+180/2=113-4*=109 and -4* for chain slack =105
The exhaust measures 31* open, 11* closed. so 31+11+180/2=111-11=100
firstly, are my calcs wright? and if so shouldnt the ex be 105 and could it be 5* out because of zepher head ( I recall a member stating that the zepher head has been allready decked by kawsaki. Is this right? cheers
When using the lobe center method to time cams, lash or checking height has no effect on the lobe center when checking a concentic cam, concentric meaning same radius on the opening and closing side of a cam. Your exhaust cam is what it is regardless of decking or lash or checking height. Pick a number and be consistant but .040"/1mm is fine with or without lash. Your intake cam though is just a guess. -4? Maybe, maybe not? In the past I have cut-up spare valve covers to replicate the center rubbing block on j/gpz motors and later made a fixture to do this. My point is your just guessing on the intake...mod
  • jimmybon
01 Feb 2007 21:59
#109657
[/quote]
When using the lobe center method to time cams, lash or checking height has no effect on the lobe center when checking a concentic cam, concentric meaning same radius on the opening and closing side of a cam. Your exhaust cam is what it is regardless of decking or lash or checking height. Pick a number and be consistant but .040"/1mm is fine with or without lash. Your intake cam though is just a guess. -4? Maybe, maybe not? In the past I have cut-up spare valve covers to replicate the center rubbing block on j/gpz motors and later made a fixture to do this. My point is your just guessing on the intake...mod[/quote]
good point, I'm goin to try and measure the -4*
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • GPzephyr
  • GPzephyr's Avatar
02 Feb 2007 00:49
#109660
modprod wrote:
make up-
gpz750 bottom end
810 pistons
gpz750r1 82 ex cams
Normally checked by putting the valve cover on and then taking off to reveal the slack in the chain.
Then using a degree wheel, wind the engine on slowly until the slack is taken up, reading off how many degrees it takes.
