Compression Ratio
- henrymski
Compression Ratio
29 Nov 2005 06:45
If you don't know the compression ratio of an engine, how do you determine it? Assume there is no published info on the engine. TIA.
- steell
Re: Compression Ratio
29 Nov 2005 06:58
Put the timing mark on TDC for #1, then measure the amount of gas/oil/kerosene is takes to fill the cylinder. That will give you the compression volume, divide the displacement by the compression volume to obtain the compression ratio.
If it's a stock motor, the specs are probably listed on the web somewhere, so you could use Google and save a lot of mess.
Post edited by: steell, at: 2005/11/29 09:59
- Ron G
29 Nov 2005 13:50
steell wrote:
Divide the displacement + the compression volume by the compession volume to obtain the compression ratio.
CR=(piston displacement+combustion chamber volume)/combustion chamber volume
Ron
Ron
- steell
30 Nov 2005 06:35
One of the nice things about this place, if I screw up there is always someone that will correct my mistake
Thanks!
Thanks!
- APE Jay
30 Nov 2005 09:08
I was just about to correct that when I scrolled down and saw Rons post.
Jay
Jay
- JR
30 Nov 2005 19:05
If stock you might find the info listed here
www.bikez.com/brands/index.php
- TwoSeven
10 Dec 2005 19:29
It will still only give an approximate as you also need to know the VE (volumetric efficiency) of the engine.
For example, a 600cc 4-stroke with a 14cc head area is going to have rough compression ratio of about 10.7:1 ratio. However, if the VE is only 90% then it means that the compression ratio will drop to about 9.7:1 or so.
It means less mix being sucked into engine, so less to be compressed.
- steell
10 Dec 2005 19:46
It will give you an exact (static) compression ratio, not an approximate one. Calculating the Volumetric Efficientcy in order to determine the dynamic compression ratio is a whole nother ball game, and I doubt that was the question.
- nads.com
10 Dec 2005 20:41
volumetricly speaking, the dynamics of the efficiency of the compression are not subjects of displacement?
- steell
10 Dec 2005 22:12Volumetric efficiency is stated as a percentage of the engines total airflow potential. (Total airflow potential, or pumping potential = displacement X rpm.) Volumetric efficiency is determind by measuring airflow into the engine while it is running.
For more info:
www.yawpower.com/martech.html
