MAC vs. Stock sound?
- c_aasland
23 Jan 2007 05:13
1982 KZ1100, Stock exhaust but right side muffler has rusted out.
Looking at replacements which aren't noisy. It appears that the MAC 4-1 is the only one available. How much noisier than stock is it?
The other alternative is to find generic mufflers and bolt on to the existing headers.
Thoughts?
Thoughts?
- Bluemeanie
Re: MAC vs. Stock sound?
23 Jan 2007 06:20
Well, It will be noisier than stock. Can't say how much, but it will be. I have a Kerker and love the 4/1 sound. You will need to rejet also. Have you checked ebay?
- 77KZ650
23 Jan 2007 06:22
going from stock to mac made my bike a bit louder in the lower rpm range, and quite a bit louder in the upper rpm range, nothing too loud, it wasnt as loud as new ninjas (till I took out the baffle:evil: )
Scott
Scott
07 MDP Rookie of the Year
- slater_kz550
25 Jan 2007 07:05
Bluemeanie wrote:
When replacing the exhaust with aftermarket parts, how do you know which jets to get for the rejet?
- OKC_Kent
25 Jan 2007 12:26
slater_kz550 wrote:
A free flowing aftermarket exhaust will flow more and your engine will need more fuel, so you go up to larger jet sizes. 1 or 2 steps on the main is a good start. Then you start reading your plugs and fine tune it from there.
Bluemeanie wrote:Well, It will be noisier than stock. Can't say how much, but it will be. I have a Kerker and love the 4/1 sound. You will need to rejet also. Have you checked ebay?
Cashion, OK
78 KZ650 B2 85,000+ miles
- KZDon
26 Jan 2007 09:43
I couldn't find stock replacement mufflers for my KZ550 so ended up with a Mac 4 into 1. Mac claims no rejetting is necessary, and once I cleaned and reset the carb adjustments to stock, I haven't felt the need to rejet. The bike still stumbles at idle until it's well warmed up, but then it's a 26 year old well used engine. It could probably use a little more air coming in from the box, but I won't play with it unless it becomes a problem.
It is not particularly louder, but it sounds like crap compared to stock. Think of an AMC pacer with a hole in the muffler. It's a farty and raw sound compared to the smooth and low roar from the stock pipes.
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
2004 650 V-Strom
- Duck
- e vica na i sau na ga
26 Jan 2007 13:39
I have a set of 87 cop bike mufflers for $50 plus ship from Atlanta. They are chrome and look fine from the top and sides. I hope to be where the bikes are on Sunday and can measure if you like.
- sheik*yerbouti
27 Jan 2007 12:27
Here is what my MAC 4-into-1 sounded like before I took the whole damn bike apart...
video.google.com/videoplay?docid=-7945586270369492607&hl=en
Here is how it stands today...
Post edited by: sheik*yerbouti, at: 2007/01/27 15:33
- rstnick
27 Jan 2007 14:06
A lot depends on what type of baffle is in the pipe. I went from a Yosh pipe with no baffle, that was very loud, to a Kerker with a street baffle, which I thought was too quite. I have grown to like it though.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- wiredgeorge
27 Jan 2007 15:13
I put a MAC black ceramic 4 into 2 on my ST as I hated the look of their 4 into 2 w/turnouts. The sound with baffles isn't all that loud. I have an S&S 4 into 2 on one of my carb test bikes and it is similiar and similar to a baffled 4 into 1 Kerker. I don't consider these systems loud. No heads turn when I am driving in town normally. At highway speeds above 80 mph, the exhaust note is somewhat louder than a stock system.
- wiredgeorge
27 Jan 2007 15:14
- sheik*yerbouti
27 Jan 2007 22:38
but where the hell is the reply to *my* post...? It's got video and everything!
(edit) - ok my girlfriend typed that when we got home while i was in the hopper...
Post edited by: sheik*yerbouti, at: 2007/01/28 01:42
