tearin' it down again..
- brianrae33
19 Jan 2007 19:48
should i use any sealant at the bottom of the barrels along with the o-rings??
1982 kz1000ltd
- kzwolfsr
Re: tearin' it down again..
20 Jan 2007 05:57
Nope, no need too, unless you need new rings!
Original man of the Caribbean
- wireman
20 Jan 2007 11:56
if you are yanking the barrel off id say spray both sides of base gasket with copper coat and let it tack up before installing it and definately use new o-rings;)
