interchangeable heads.
- DaytonaMC
- You keep for your collection, I know you like it.
19 Jan 2007 18:13
i was just wondering if heads for a 1977 kz1000 would fit a 1979 kz1000 and vice versa? i looked on kawasaki.com and found parts diagrams and the p/n is different but, i was wondering if they supercede and, were in fact interchangeable.thanks
I must remove my skin.....
- wireman
Re: interchangeable heads.
19 Jan 2007 18:21
it should physically interchange but the cam sprockets are differantB) so you need to swap cams
- DaytonaMC
19 Jan 2007 18:28
thanks wireman, i appreciate it.
so, now does anybody have a head for a 77 1000b1 that they do not need?
- racer54
19 Jan 2007 18:29
All heads from 1973-1980 Z1's and KZ's will interchange. Thing to look for is if the '79' is a MK11...like wireman says about the cam sprockets.
Post edited by: racer54, at: 2007/01/19 21:32
- DaytonaMC
19 Jan 2007 18:32
so if it is not an mkII it should fit my b1 with out any modifications?
- wireman
19 Jan 2007 18:35
any of them will fit,just use your cams so you know you have cam sprockets that match your sprocket on crank;)
- racer54
19 Jan 2007 18:37
A MK11 head will fit your motor, it's just that you would need MK11 cam sprockets to go with the MK11 crank(more teeth on crank center pin so cam sprockets need to be MK11), otherwise it will work. Just use you stock cams, etc. in the MK11 head. Any head from '73-80' will work on your motor, even the MK11. Yes...it will fit without modifications.
- DaytonaMC
19 Jan 2007 18:40
do you think mkII cam sprockets from a kz650 will fit or are they different?
- wireman
- DaytonaMC
19 Jan 2007 18:46
i have a kz650 with mkII heads that is just sitting in my garage, i was wondering if i could rob cam sprockets and, top rollers from it to use on my 1000.
- racer54
19 Jan 2007 18:48
No MK11 kz650's to my knowledge.
- racer54
19 Jan 2007 18:49
What makes you think it is a MK11 head on your 650?
