interchangeable heads.
  • DaytonaMC
  • DaytonaMC's Avatar Topic Author
  • You keep for your collection, I know you like it.
19 Jan 2007 18:13
#106909
i was just wondering if heads for a 1977 kz1000 would fit a 1979 kz1000 and vice versa? i looked on kawasaki.com and found parts diagrams and the p/n is different but, i was wondering if they supercede and, were in fact interchangeable.thanks
I must remove my skin.....
  • wireman
  • wireman's Avatar
Re: interchangeable heads.
19 Jan 2007 18:21
#106912
it should physically interchange but the cam sprockets are differantB) so you need to swap cams
  • DaytonaMC
19 Jan 2007 18:28
#106916
thanks wireman, i appreciate it.
so, now does anybody have a head for a 77 1000b1 that they do not need?
  • racer54
  • racer54's Avatar
19 Jan 2007 18:29
#106918
All heads from 1973-1980 Z1's and KZ's will interchange. Thing to look for is if the '79' is a MK11...like wireman says about the cam sprockets.
Post edited by: racer54, at: 2007/01/19 21:32
  • DaytonaMC
19 Jan 2007 18:32
#106920
so if it is not an mkII it should fit my b1 with out any modifications?
  • wireman
  • wireman's Avatar
19 Jan 2007 18:35
#106922
any of them will fit,just use your cams so you know you have cam sprockets that match your sprocket on crank;)
  • racer54
  • racer54's Avatar
19 Jan 2007 18:37
#106925
A MK11 head will fit your motor, it's just that you would need MK11 cam sprockets to go with the MK11 crank(more teeth on crank center pin so cam sprockets need to be MK11), otherwise it will work. Just use you stock cams, etc. in the MK11 head. Any head from '73-80' will work on your motor, even the MK11. Yes...it will fit without modifications.
  • DaytonaMC
19 Jan 2007 18:40
#106928
do you think mkII cam sprockets from a kz650 will fit or are they different?
  • wireman
  • wireman's Avatar
19 Jan 2007 18:43
#106930
:blink: ?
  • DaytonaMC
19 Jan 2007 18:46
#106933
i have a kz650 with mkII heads that is just sitting in my garage, i was wondering if i could rob cam sprockets and, top rollers from it to use on my 1000.
  • racer54
  • racer54's Avatar
19 Jan 2007 18:48
#106934
No MK11 kz650's to my knowledge.
  • racer54
  • racer54's Avatar
19 Jan 2007 18:49
#106936
What makes you think it is a MK11 head on your 650?
