650 engine /cam timing
  • Larry2882
  • Larry2882's Avatar Topic Author
19 Jan 2007 15:55
#106883
:) with number one piston at tdca which way are the lobes on the cam for number one pointing when replacing the cams back on the head?
  • BSKZ650
  • BSKZ650's Avatar
Re: 650 engine /cam timing
19 Jan 2007 16:03
#106884
dont have my book in front of me, but seem to remember marks on the gears that line up with the gasket surface, I will have to look later to be sure
77 ltd1000, current rider
76 kz900, just waiting
  • RonKZ650
  • RonKZ650's Avatar
19 Jan 2007 16:13
#106885
Of course the lobes are going to be facing away from the buckets because at TDC on cylinder one you will need compression to run. Arrow on your exhaust cam should line up to the front top surface of your head, intake cam arrow should line up with the top rear surface of your head. Start counting camchain links at 1 the first pin from the arrow, count 36 pins on your camchain and #36 should be on your other arrow.
  • Larry2882
19 Jan 2007 16:30
#106889
thanks for the info on the cam timing. need three more bits of info. torque on head bolts and cam cap bolts in psi and points and plugs gap in metric or inches.thks.again.
  • Larry2882
Re: 650 engine. points gap,head bolt torque
19 Jan 2007 17:04
#106893
tnks for info on cam timing.also need points gap and torque on head bolts and cam cap bolts.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
19 Jan 2007 17:07
#106895
Welcome Larry.
Head Bolts: 2.2~2.8 kg-m / 16~20 ft-lbs.
Head Nuts: 3.7~4.3 kg-m / 27~31 ft-lbs.
Camshaft cap bolts: 1.1~1.3 kg-m / 95~113 in-lbs.
Point gap: 0.3~0.4 mm.
Spark plug gap: 0.7~0.8 mm.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • Larry2882
Re: KZ650 Used Repair Manual
19 Jan 2007 17:30
#106898
Do Any one have a repair manual for a KZ650 1976-78
Thanks
  • Larry2882
Re: kz1000 igniter
20 Jan 2007 09:17
#107042
the igniter on my bike is damaged and has to be replaced.somebody.cannot find again on this site, replaced this igniter with a GM HEI module. can they let me know year and make of car or truck that carries thi module and where it is located on the engine tnks.:)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: kz1000 igniter
21 Jan 2007 09:15
#107228
Check out the Archives. Found this post:
kzrider.com/forum/viewthread.php?tid=27518
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • Larry2882
22 Jan 2007 15:28
#107492
still having a problem understanding this valve timing.pointed ends of ext and int lobes facing each other, or facing away from each other on number 1 cyl at tdc. what do you refer to as "the buckets"?
  • Larry2882
22 Jan 2007 15:30
#107493
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Jan 2007 17:18
#107512
The buckets are right below each cam lobe. The valve clearance is measured between the buckets and the cam lobes.
I'm not sure of the position of the lobes during setting up of the cam timing. You will be looking at the timing marks on the cam gears. The exhaust gear's mark lining up with the head surface to the front, and the intake gear's mark lining up with the head surface to the rear.
Post edited by: rstnick, at: 2007/01/22 20:41
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
