Cams
- KZG1
Cams
18 Jan 2007 05:10
hows everybody doing? whats the bigest cams you can go with without having to clearance the head? aftermarket or any good grinds from GPZ motors?
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
84 GPZ1100
Honda Trail 70
- KZG1
Re: Cams
18 Jan 2007 05:48
looking for more HP
80 KZ1000G1
84 GPZ1100
Honda Trail 70
84 GPZ1100
Honda Trail 70
- wiredgeorge
Re: Cams
18 Jan 2007 06:08
I think the Megacycle Cams web site has a decent explanation for the different grinds and what it takes to run them. You will have to do some research on OEM cam profiles as I don't know anyplace where they are listed.
- Sandy
- Fly High,Tony
Re: Cams
18 Jan 2007 07:55
I'm using the APE 410 cams,and I had to clearance the head for these to run.I also had to clearance the valve-cover as well.
1977 KZ1000 A-1
- RomSpaceKnight
Re: Cams
18 Jan 2007 23:15
I have 380 and clearanced the head but not the valve cover. Just a bit shaved of. Can be done at home. No big tech knowledge needed for a bit off.
