81 KZ1000 Rotor removal, stuck tight!
  • 82KZ1000LTD
  • 82KZ1000LTD's Avatar Topic Author
12 Jan 2007 09:41
#105180
I'm trying to remove the rotor assembly from my 81 KZ1000J model because it slips out of engagement when turning the bike over with the starter. I believe the pins are worn so I need to check it out. I don't have a rotor puller and tried using the rear axle which is the same right hand thread size but it wont budge. I'm thinking of ordering a puller for this bike but is there any other methods of removing this thing. Thanks.
  • larrycavan
  • larrycavan's Avatar
Re: 81 KZ1000 Rotor removal, stuck tight!
12 Jan 2007 09:59
#105182
The OEM Kawasaki puller is a double threaded end deal with a section in the middle to get a wrench on. [at least that's how it used to be] Get one, have it cut in half and then weld a nice size rod to form a T-Handle on the end of each threaded section. Use a hammer on the T-Handle to get the Rotor loose.
Somoetimes oil in the end of the crank can help to hydraulic the object off the crank. I used that trick on many a snowmobile clutch over the years...
Be careful you don't mess up the threads in the crank end!
  • Kiwiz
  • Kiwiz's Avatar
13 Jan 2007 13:44
#105439
Have a look at this recent post on the UK owners site!
www.z1ownersclub.co.uk/forum/viewtopic.php?t=756
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
14 Jan 2007 08:20
#105553
I borrowed a Friends dent-puller from His Body-Shop...worked like a charm on the one I was having a fight with.B)
1977 KZ1000 A-1
  • 82KZ1000LTD
26 Jan 2007 12:24
#108334
Thanks for all the help on this problem. I finally got it off with a rotor puller, a copper washer and a sextrillion pounds of torque. The three hex head screws where broken and stripped out. I was able to drill and tap new mounting holes and with three new bolts and some blue loctite I reassembled the assembly and it now works great. Thanks again.
  • kzwolfsr
  • kzwolfsr's Avatar
26 Jan 2007 18:50
#108416
Do you have any pics of your bike? I have the same bike, but I changed the handlebars. I have some pics, but its at night. Lemme show you.
Post edited by: kzwolfsr, at: 2007/01/26 21:51
Original man of the Caribbean
