heeeeeeeeelpppp!!!!
- rigidkz
heeeeeeeeelpppp!!!!
09 Jan 2007 14:08
ok i have a problem i rebuild my kz650 cleaned, new gaskets an seals) now i have put it back in time checked for spark,it has spark, checked for fuel,has plenty of fuel, plenty of voltage. an the damn thing will not start. any ideas?????
- ltdrider
Re: heeeeeeeeelpppp!!!!
09 Jan 2007 14:21
Timing?
You can have spark, but if it not at the right time in the compression cycle, it won't run. Did you adjust the timing plate?
If you have electronic ignition, please disregard this.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- thebull
09 Jan 2007 14:26
Keep it simple, an engine only needs three basic things to run, compression, fuel and a spark. If you are sure you have all three then you probably don't have them all at the right time. If you don't even get
a backfire or popping then something is way off. The first thing I would do is to reference your manual and go back and check your cam timing and make sure you've referenced the cams to the proper cylinder. Good Luck, thebull
- rigidkz
09 Jan 2007 14:34
i put the timeing plate in the middle where it is suppose to be an i set the cams where they are suppose to be but you know now that i have sat down an thought about it i have not checked for compresion yet hello i guess i will start there. thanks
- z1kzonly
09 Jan 2007 14:42
HOW ABOUT HAVING YOUR IGNITION ADVANCE UNIT OFF BY 180 DEGREES?
THIS HAPPENS ON THE 900'S. THERE IS A LITTLE PUNCH MARK THAT HAS TO GO A CERTAIN WAY. CHECK WITH A FACTORY MANUAL. THIS EXPLAINS IT.
MARTY IN BUFFALO, HARLEY AN KAW OWNER
- flht1997
09 Jan 2007 14:58
check that you have the ignition hook up right. may have the coil wires backwards.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- 77KZ650
09 Jan 2007 14:59
I second the 180 out idea, it will spark, just at the wrong time.
z1kzonly: try not to YELL on here plz:) some members dont like the caps lock. thx
Scott
Scott
07 MDP Rookie of the Year
- Bluemeanie
10 Jan 2007 06:15
Yup... Timing is everything
