Head cover leak....
  • Draco
  • Draco's Avatar Topic Author
Head cover leak....
08 Jan 2007 11:39
#104206
I have slight leaks in the areas indicated below. Would a head cover gasket solve this or would I need these from Z1: cam end plugs ?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Head cover leak....
08 Jan 2007 11:49
#104209
I suggest both (to cover all your bases). Jeff sells the valve cover gasket separately and also the cam plugs...make sure you get the correct adhesive for the cam end plugs (Jeff sells that too :laugh: )
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Draco
08 Jan 2007 11:51
#104210
Where is the cam plug adhesive on the site?
Also, is it just a matter of popping the old ones out ans putting new ones in? Or is it a more involved procedure?
I don't have a service manual yet..
Post edited by: Draco, at: 2007/01/08 14:56:S
Post edited by: Draco, at: 2007/01/08 15:01
  • mariozappa
  • mariozappa's Avatar
08 Jan 2007 13:24
#104240
The cam end caps are held in by a bolt that holds the valve cover on. When you take the cover off, the end caps will be able to come off.
I think adhesive is threebond 1104?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Draco
08 Jan 2007 15:47
#104292
So I assume that you would put adhesive around the sides that contact the head? (round part, and side that faces out?)
  • pumps
  • pumps's Avatar
08 Jan 2007 19:44
#104350
I have that seep on the front on both sides of mine too. By the way the new paint looks great...in case no one else has told ya my friend. Doesn't it guys?;) ;)
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • mariozappa
09 Jan 2007 05:48
#104412
When I did mine, I put adhesive on the head and all around the edges of the end caps(very thin) and just bolted the valve cover down after it was dry.
It will be very apparent when you take it apart.
And yes, :) Nice paint job.
1977 KZ650C1
  • mariozappa
09 Jan 2007 05:50
#104413
Oh yeah, when you do this. To avoid future leaks, make sure you remove all the old gasket and DON'T gouge the mating sufaces.
1977 KZ650C1
  • Draco
09 Jan 2007 06:16
#104414
Gotcha, thanks for all the tips and info MZ! It is truly appreciated. And thanks for the compliment on the paint, not bad for a rattle can job, eh?
  • mariozappa
09 Jan 2007 06:29
#104415
It looks awesome for a rattle can job.
B)
1977 KZ650C1
