Automotive sub for an oil pres switch
  • 81Red750
  • 81Red750's Avatar Topic Author
08 Jan 2007 10:19
#104175
Does anyone know of an automotive equivalent for an oil pressure switch? Either that, or a cheaper place to get on than the $69 I've seen everywhere. BTW, I have an 81 kz750-4.
Thanks!
Corey
  • steell
  • steell's Avatar
Re: Automotive sub for an oil pres switch
08 Jan 2007 17:38
#104313
That's just a simple on/off switch that triggers a light, so pretty much any switch off a car with a light instead of a gauge will work.
If you are not in a big hurry PM me your address and I'll send you a used one for the cost of mailing it.
Might take me a couple of weeks to get around to digging one out.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
08 Jan 2007 17:56
#104317
Most automotive senders are set between 4-7 PSI to turn on or off the light :)
  • steell
  • steell's Avatar
08 Jan 2007 19:43
#104349
What is the one on the 650/750 motors?
The 750 twin is probably the same since it is a plain bearing motor also.
  • 81Red750
08 Jan 2007 20:52
#104376
if it'll work, I'm all on board Steve! Let me know if Paypal'll work and how much
