  • H1Vindicator
  • H1Vindicator's Avatar Topic Author
06 Jan 2007 09:32 - 21 Feb 2013 21:00
#103711
Last edit: 21 Feb 2013 21:00 by H1Vindicator.
  • oldcoldankles
  • oldcoldankles's Avatar
Re: Patching holes drilled into muffler ends
06 Jan 2007 09:49
#103713
What would you think of tapping the holes then filling them with stainless steel socket head cap screws?
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • H1Vindicator
Re: ----
06 Jan 2007 10:02 - 21 Feb 2013 21:00
#103720
  • pumps
  • pumps's Avatar
06 Jan 2007 13:24
#103756
Are you talking about holes in the sides of the end?In the chrome ? Or in the ends as you would look from behind and see? If in the sides maybe some kind of tip to cover?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • oldcoldankles
06 Jan 2007 14:17
#103766
Here's another idea. Install threaded inserts of the type used to make attachment points in panels. The ones I use on truck control panels are aluminum but other materials are available. Then thread ΒΌ" stainless steel socket head capscrews into them.
www.hansonrivet.com/w67a.htm
Post edited by: oldcoldankles, at: 2007/01/06 17:20
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
  • H1Vindicator
Re: ----
06 Jan 2007 14:41 - 21 Feb 2013 21:04
#103770
Last edit: 21 Feb 2013 21:04 by H1Vindicator.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
06 Jan 2007 15:18
#103778
I bought a Suzuki once that had that done to it ,, I cut off Carrage bolts and used the heads to fill the holes then I tac welded them into place it worked out and after a spray of black heat paint didnt look to bad either ,, Just an idea :)
  • H1Vindicator
Re: ----
06 Jan 2007 15:57 - 21 Feb 2013 21:04
#103802
  • Shoe48
  • Shoe48's Avatar
06 Jan 2007 16:02
#103805
It did not on mine ,,,the metal is thin there so I ran a low heat on my Mig Welder:)
  • H1Vindicator
Re: ----
06 Jan 2007 16:15 - 21 Feb 2013 21:03
#103811
Last edit: 21 Feb 2013 21:03 by H1Vindicator.
07 Jan 2007 08:32
#103929
Here's some more info about "nutserts"
www.imperialinc.com/grp270.shtml
and how to install without the special tool
www.318ti.org/notebook/nutserts/index.html
07 Jan 2007 08:32
#103930
delete duplicate post
Post edited by: Patton, at: 2007/01/07 11:48
