That new cylinder head you just bought?
  • wiredgeorge
  • wiredgeorge's Avatar Topic Author
26 Nov 2005 12:51
#10367
Well... If you have ever bought a new cylinder head and have NO clue as to whether the valve clearances are any good after you took it apart, cleaned it up, and then put it together again...
The 77-80 KZ1000 Kawasaki Motorcycle Service Manual has a neat chart that tells you which shim to use when reassembling after you have measured the valve stem length. I spent a few minutes typing the darn thing into a MSWord file and put it in the non-model specific Filebase area.
kzrider.com/component/option,com_docman/.../gid,240/Itemid,231/
The reason I found this darn thing in the manual I already owned is that azchili pointed it out to me. Good catch!!! Thanks.
  • BohicaBob
  • BohicaBob's Avatar
Re: That new cylinder head you just bought?
26 Nov 2005 14:34
#10381
Thanks a bunch for taking the time to do this! I certainly appreciate it.:)
  • azchili
  • azchili's Avatar
26 Nov 2005 21:52
#10433
thanks wg.thats the chart i was trying to send.it's a big help.i used mine today reassembling my engine and it got me in the ballpark.
  • wiredgeorge
28 Nov 2005 06:08
#10620
I bought a cylinder head some time ago from a friend (Brian Connell kzmoney99 on ebay) and it was in great shape except for a broken exhaust stud. The vavles look about as nice as I have seen on a used head. I marked the shims when I disassembled it and will check later today maybe or tomorrow to compare against the stem lenghts I measured to see if the head was shimmed proper before removing it from the donor bike. Will report on what I find but I will reassemble with the shims suggested in the chart.
  • CruisingRam
  • CruisingRam's Avatar
29 Nov 2005 07:45
#10878
Thanks alot- great info!
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
