kz1000r and a gpz1100b1 cranks same?
- kano
- Not Another Bloody Limey!
31 Dec 2006 21:58
hi guys.
is a crank from a kz1000r and a gpz1100b1 the same otherwise i may as well sell it i thought i read somewhere the con rods were different length and the pin diameter where different too.
only reason i ask is im thinking of re building it and getting it welded for a spare.
Post edited by: kano, at: 2007/01/02 08:13
- steell
Re: kz1000r and a gpz1100b1 cranks same?
02 Jan 2007 05:23
The kawasaki parts diagrams are
Here
and you can look up the part number for the crank on both models. If the part numbers are the same, then the cranks are the same, if the number is different, then they may still interchange but it takes experience to know.
I just checked and the part numbers are identical.
