KZ750GT tapping noise in top end driving me nuts !
- highspeedjelly
27 Dec 2006 23:43
Can someone help me ?The bike has a tapping noise which sounds like it is in the top end.If you place your head on the tank at idle,it sound exactly like a one valve with excessive clearence which hammmers away louder as the revs increase.I booked the bike into a dealer to get the valve clearences done.He found a couple of tight valves but nothing with excessive clearence.
It runs like a dream now apart from the noise which is still there.
I pulled the auto tensioner out and was delighted to find it was locked up solid.I polished the faces of the wedge contact surfaces cleaned and reassembled it and made sure it was working correctly,thinking it would be problem solved.It was not.
All I can think of now is the cam chain has stretched enough to be beyond the range of the auto tensioner and maybe a manual one would do the trick?
Having said all of that,it does not really sound like cam chain rattle anyway.
Any ideas or suggetions would be appreciated.The bike has 68000ks on it.
- RonKZ650
Re: KZ750GT tapping noise in top end driving me nuts !
28 Dec 2006 07:09
Has the exhaust been removed from the head recently? Most "valve clatter" is actually exhaust leaks.
- Biquetoast
- King Jeremy The Wicked
28 Dec 2006 10:01
RonKZ650 wrote:
Can you disconnect one of the plugs at a time while the engine is running to see if the noise stops?
Sounds crazy, but it is true. The same happened to me. I had swapped exhaust without changing the crush gaskets. The noise sounded exactly like a metal tapping, but was an exhaust leak.Has the exhaust been removed from the head recently? Most "valve clatter" is actually exhaust leaks.
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- highspeedjelly
28 Dec 2006 20:56
Thanks for help.Checked carefully but not exhaust leaking.I have to assume the dealer checked clearences correctly but it sure sounds like it is valve related.Can a slack cam chain make a noise similar to this?
:dry:
:dry:
- kzwolfsr
28 Dec 2006 21:03
Yeah, mine has this rapping noise when cold and a guy who checked out my bike told me it could be the cam chain. I bought a manual chain tensioner to see if that will help also. I dont know if it will work yet because the engine isn't put together yet.
Original man of the Caribbean
- franknsr
13 Jun 2007 21:40
Oh man...I've got the same top end noise. Hoping its just the exhaust gaskets. Thanks guys for saving me a trip inside the head...I hope.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
13 Jun 2007 22:08
highspeedjelly wrote:
Don't bet the farm. :ohmy:
...assume the dealer checked clearences correctly....
