carbon build-up!
- steveo_4192003
- 77kz650b-1
carbon build-up!
26 Dec 2006 18:02
i got my head and block apart and i see a lot of build-up of carbon (29 yrs) really,really bad!!
whats the best way to clean this mess up
heres a pic of it
heres a pic of it
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- steell
Re: carbon build-up!
26 Dec 2006 19:02
I use one of those little brass wire brushes on a Dremel at low to medium speed, do "NOT" run one at high speed or you will be picking brass wires out of your skin for two weeks (need I say how I know that?).
Eye protection required of course
Post edited by: steell, at: 2006/12/26 22:03
- steveo_4192003
- 77kz650b-1
26 Dec 2006 19:18
i was also thinking a brass brush! low speed of course
just wanted reassurance it was safe!!!(for head)
- wiredgeorge
27 Dec 2006 06:09
I suggest you go to the Walmart and pick up a fine steel wire wheel that fits on your drill. You can clean away and not hurt the combustion chamber. I wouldn't hold the wheel for long periods on the valve seats nor any power tool; even a Dremel with a brass brush on the seats. The carbon you have is fairly normal.
- BSKZ650
27 Dec 2006 16:55
a good blast with carb cleaner will get a lot of the light stuff off first, then go after it with a soft wire wheel, be easy, a wire wheel can eat alum
77 ltd1000, current rider
76 kz900, just waiting
- nads.com
27 Dec 2006 21:16
Use a wire wheel like George said. If you keep blasting it with carb cleaner it comes off much faster. When the wheel's bristles start to bend in one direction, reverse the drill's direction.
Post edited by: nads.com, at: 2006/12/28 00:17
