kz 750 twin oil filter location
  • ndali
  • ndali's Avatar Topic Author
20 Dec 2006 11:05
#100701
I am looking for the location of the oil filter on my 82 kz 750 twin. It is not in any of the usual places so I am assuming it is hidden under a panel somewhere.
  • Steve M
  • Steve M's Avatar
Re: kz 750 twin oil filter location
20 Dec 2006 11:28
#100703
Hope this pic helps. Got it from www.buykawasaki.com
Post edited by: Steve M, at: 2006/12/20 14:31
  • Steve M
  • Steve M's Avatar
20 Dec 2006 11:36
#100704
Sorry i'll try the pic again.
  • Nevco48
  • Nevco48's Avatar
20 Dec 2006 11:45
#100707
They did a pretty good job at hiding it. You need to take off your front sproket cover, which means removing the shift lever, and I think the left foot peg bracket too.
crap, I'm giving semi-technical advice again, I better get back over to ChitChat with the other bozos...:pinch:
  • ronjones
  • ronjones's Avatar
20 Dec 2006 12:38
#100723
Ya got it right, Nevco. You do have to remove the left foot rest as well as the shift lever, to remove the front sprocket cover.
Ron
  • steell
  • steell's Avatar
20 Dec 2006 15:03
#100746
By the way, you see that little bolt at the bottom of the cover in the pic above?
That is the oil filter drain bolt, remove it and drain the filter housing before removing the big bolt in the center.
Don't ask me how I know this :D
  • ronjones
  • ronjones's Avatar
20 Dec 2006 19:50
#100826
Yeah, that messed me up, also, Steve;)
