Minor engine problem?
- Scoobydo0s
24 Nov 2005 13:30
I have a 82' KZ750-e3 and most of the time the engine runs fine. But every so often it seems like one of the sparkplugs isn't firing correctly and I've stalled out of nowhere or it backfires with the smell of gas. I am going to be replacing all the sparkplug wires and sparkplugs. Also might have someone look at the distributor for the bike just to make sure it's not failing. Beyond that I can't think of anything else to have done. Any other ideas as to what it might be?
I hope to mod this bike out and make it a little more sleak. Was thinking of custom building a new tail and maybe moding the seat a bit. Any suggestions or ideas would be greatly appreciated.
Thanks all.
Thanks all.
- KZQ
- Administrator
Re: Minor engine problem?
24 Nov 2005 15:47
Hey Scoobydo0s,
Kaws don't have distributers so you needn't go looking for one. I suggest that you're going in the correct direction when you say you're planning to replace the wires and plugs. That'd be a good first step. Also check the voltage to the primary side of the coils. Should be right up there at 12 or 12.5 volts. If it's lower than 12 volts start checking the connections back to the regulator and battery. Use some electrical contact cleaner along with a small wire brush to remove any corrosion you may find on the connections. Before reassembling them give them a little squirt of dielectric grease. It'll stave off further corrosion.
KZCSI
Post edited by: kzcsi, at: 2005/11/24 18:52
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Scoobydo0s
25 Nov 2005 23:20
thanks for the help. this is the first motorcycle I've owned so I don't know much so thanks again.
