650 clutch cover window
- flht1997
18 Dec 2006 15:03
seen these things on ebay going for a bunch of money so i am trying my hand at making one. i aways liked the ducati's and honda's with the exposed clutchs, so i guess this it the next best thing for a kz. any one have/make one before. i assume it will leak a little bit just because of the slightly irregular surfaces
edit: yea i dont change my calander much. and i did the program on a two axis bridgeport mill
Post edited by: flht1997, at: 2006/12/18 18:05
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- 77KZ650
Re: 650 clutch cover window
18 Dec 2006 17:30
If you machine it with accurate equipment and use the proper seal, it should be fine. if you cant get it to work, I know of a company that can make one for you, they do points covers too, pretty cool stuff, Im thinking of getting some stuff from them in the future.
Scott
Scott
07 MDP Rookie of the Year
- rstnick
18 Dec 2006 19:19
I'd love to have one, and a points cover too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- pumps
18 Dec 2006 23:58
I would think you can get it to seal. Seems like maybe I saw one with an LED light in it. You could even etch it like I have seen them etch windows on the side of pc cases. Maybe etch KZRider.com on it !
Post edited by: pumps, at: 2006/12/19 03:00
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- pyxen
19 Dec 2006 05:24
Erm..do you not have a wet clutch in there? Wouldn't that just dirty up the window, and make it so you have a nice (hopefully) amber window eventually?
..or is it a dry clutch?
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- flht1997
19 Dec 2006 07:23
yea i know it is going to be drippy brown madness in there when it is running, i thought i would just run it real low on oil
(not really)
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
89' BMW R100RT
06' KLR650
- trippivot
19 Dec 2006 08:51
that is cool !!
might try a layer of rubber to seal around the edge.
or "O"-Ring the case around the window.
I have a extra cover for you to do -- if you get a good seal. MY GS would look good with one too.
- mariozappa
19 Dec 2006 10:31
Twowheeledterror had a thread on here about one he was making. All pics are gone now, and I think that thread turned into a flame war before if was ever finished.
I would like to see your completed and on the bike!
1977 KZ650C1
and the KZ650/KZ750 Conversion
- kzwolfsr
20 Dec 2006 07:19
very interesting
I will look for a spare cover and try that, and I will once I pit my mind to it.I dont have glass but I am sure see through pastic will work!
Original man of the Caribbean
- Pterosaur
20 Dec 2006 07:44
flht1997 wrote:
No direct experience with such animals, but a few ideas:
Not sure about clearance issues, but might the glass *look* better if it were mounted to the inside of the case?
Since you've got access to the Bridgeport, might be a worthy idea to hunt up a good quality O-ring (as mentioned elsewhere) of the appropriate size and machine a groove in the case between the opening and the mount screws to form a seat/seal. That'd go a long ways towards preventing that *drippy* issue.
Might also be an idea to fab up an aluminum ring to match the mount circumference and holes - it'll distribute the stress placed on the view plate when torquing down the bolts and aid any seal arrangement you come up with.
It'll certainly give you incentive to change your oil regularly - black goo getting slung all over the porthole will definitely get noticed at bike nights...
Best of luck - an interesting idea
yea i know it is going to be drippy brown madness in there when it is running, i thought i would just run it real low on oil(not really)
- caffcruiser
20 Dec 2006 08:35
FWIW: Klasmo GMBh makes these too... and they don't bolt their panels in.
You have to consider that the pressure exerted will be pushing OUT on the window... a window on the outside is a recipe for leakage.
Klasmos are inside... and they are retained by some form of adhesive.
Post edited by: caffcruiser, at: 2006/12/20 11:35
- Pterosaur
20 Dec 2006 08:42
caffcruiser wrote:
Might be worth toying around with masking the appropriate lip area of the transparency and bead blasting, doing likewise with the inner edge of the cover and JB Weld-ing the porthole into place.
Did a shade-tree repair to a guy's radiator with the stuff (JB) one time - and 3 years on, it's *still* holding - so temperature issues shouldn't be a problem, and stressing the transparency by torque differential on bolts/vibration is minimized as well.
Good stuff from CC.
Good stuff from CC.
