cam chain !!
- steveo_4192003
- 77kz650b-1
cam chain !!
17 Dec 2006 21:27
do i need the chain splitter to remove my cam chain?
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- Sandy
- Fly High,Tony
Re: cam chain !!
17 Dec 2006 21:58
Prop the chain up,away from the engine...cover the engine with rags to keep anything from getting in,and use a mini-grinder(or a dremel).
1977 KZ1000 A-1
- CoreyClough
- GPz550 Addiction
Re: cam chain !!
18 Dec 2006 05:10
Definitely grind away at the two pins you are wanting to remove first. Makes removal much easier. Just like when you remove a link from your drive chain, but in a smaller case.
I've jus replaced mine and had a few issues with the tool.
kzrider.com/component/option,com_joomlab...d,2/id,98852/#100193
Managed to get the new chain installed.
Why are you replaing the cam chain anyways?
'85 GPz550(ZX550-A2)
- baldy110
