Carburetor O-ring Kits
  • Nessism
  • Nessism's Avatar Topic Author
03 Dec 2025 09:00 - 03 Dec 2025 13:04
#919527
Each set covers a set of 4 carbs.  Cost is $21 shipped in the US, and $2 extra outside the country.  Message for payment info (paypal, or cash).
All O-rings are Nitrile/Buna-N. These O-rings will swell slightly with gasoline contact, which helps improve the seal.
Mikuni VM Kit (VM26, VM28 (later version, not the Z1 version carbs), VM22, VM24
- 4 Pilot Fuel Screw O-rings
- 4 Pilot Air Screw O-rings
- 4 Drain Screw O-rings
- 4 Choke Plunger Cap O-rings
- 4 Bleed Pipe O-rings
- 4 Accelerator Pump nozzle O-rings (optional)
Most sets won't need all these parts, but I include them to keep it simple.  If you want Optional O-rings for an accelerator pump, let me know in advance.
I also have O-rings for the most common size Fuel Tee & Transfer Tubes.  If you want some of those, again, let me know in advance.
Mikuni BS/CV Kit (BS34, BS32)
- 4 Float Valve Seat O-rings
- 4 Pilot Plug O-rings
- 12 Fuel Tube & Vent Tee O-rings
Again, most sets won't need all these O-rings, but they are included regardless.
Keihin CV34 Kit (KZ750).  These also fit the later year 440 ($15, for a half kit)
- 4 Float Bowl O-rings
- 4 Pilot Screw O-rings
- 10 Fuel Tee, Transfer Tube, Vent Tee O-rings
Lastly, for those folks with the highest desire for DIY, I offer Mikuni Choke Plunger Viton rubber donuts for $20/set.
5 donuts per kit of carbs (one extra, because they are tricky to install).  To remove the old seals, dunk the plungers in carb dip for a couple of days to soften the rubber.  Heat can also be used, but that requires more care.  To install, use silicone grease, a small screwdriver, your fingernails, and in my case, an old pick tool recontoured into a spoon shape.  It's not easy to install these seals, but it's very doable (I've done more than a dozen sets of plungers).  These donuts are flat, so if you have the later year BS34 carbs, with a raised lip on the rubber seal, these won't replicate that feature.
Contact via Private Message or email to nessism AT sbc global DOT net
Thanks
Last edit: 03 Dec 2025 13:04 by Nessism.
The following user(s) said Thank You: KZQ, TexasKZ, MFP-Joe, sf4t7, 78kawltd, Wookie58, kimchella
  • Nessism
Re: Carburetor O-ring Kits
05 Dec 2025 10:54
#919571
At this time of posting, I have several sets of accelerator pump diagrams, and a bunch of fuel tee's for center feed VM carbs.  If you need fuel Tee's for the "dual feed" VM26's, I can accommodate those as well, by modifying the center feed Tee's on my lathe.  Message or email to discuss as needed.
The following user(s) said Thank You: KZQ, SWest, kimchella
