it turns out that suspension matters...
  • bound
  • bound's Avatar Topic Author
Re: it turns out that suspension matters...
04 Jun 2026 12:45
#924605
I've been fishing my whole life. There's nothing quite like going out on a small lake with a canoe and casting along the lily pads with family.
I obviously physically can't fix the bike in my current state but my mind can't stop wandering!!!   You're right,  it's almost a need, kind of like when you feel it just isn't running quite right so you spend all day syncing the carbs,  rechecking valve clearances, etc.
1982 KZ1000M2 CSR - testing phase
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • Nerdy
  • Nerdy's Avatar
  • Away
04 Jun 2026 13:17
#924606
Lost my reply somehow.  Here it is again.
Thank you for watching the video.  Resonant frequency is the salient point.  The energy input for the bridge was the wind but it could be any source.  On a motorcycle it is the combination of suspension, center of mass and tire pressure.  Change any of these variables and you will change the resonant frequency to a different speed.
Appreciated, but I watched the video a few decades ago :-D It's practically required viewing for any physics or engineering undergrad
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
04 Jun 2026 16:26
#924609
With regards to the suspension mods - take a breath and do some research- you will Ned access to a lathe, a friendly machine or plenty of money. A lot of the bikes you see with these conversions are badly engineered death traps that are inherently unstable. Pretty much all the later sports bike front ends are too short and fitted as they are will make tank slappers a regular occurrence. This means they need extending/adapting to work as intended and retain reasonable geometry. I am using 98 ZX9R RWU forks in my 82 Ltd and they needed 70mm extensions to retain the geometry with a 17 inch wheel (also ZX9R) these parts aren’t available off the shelf so you will need to tell the machinist what you want. You will also need a modified/custom stem. Don’t want to be a kill joy but if you get it wrong you will be back in the emergency room or worse. There is a lot more to it than bolting parts on !!!!
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7, Dragbike_Mike, bound
  • bound
04 Jun 2026 17:40
#924611
I changed my mind pretty quickly!!! I started adding up the cash amounts for everything and WOW! It just adds up like crazy and the mechanical calculations and work id need is beyond me. I still want to upgrade in some way so I'll be looking at more mild kz1000 police forks instead with their 300mm rotors. I think that's a lot more achievable. I have this problem where my brain gets excited and thinks of things a lot differently from what they actually are
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
05 Jun 2026 00:23 - 05 Jun 2026 00:29
#924615
Your CSR has "leading axle" forks so switching to a "P" would also require the "P" trees or the "Trail" will be excessive and effect the steering. As long as they are straight the best bet would be to re-bush the stock units (or some from a Ltd) fit progressive springs and possibly heavier oil (how heavy are you) then blank off the "air ports" if it has a balance pipe
Last edit: 05 Jun 2026 00:29 by Wookie58.
The following user(s) said Thank You: bound
  • bound
05 Jun 2026 06:23
#924618
Anything I do with regards to forks will be basically the whole front end. Call me crazy but I think I would need new forks. If you can tell in the picture of my bike, the wheel is pointing in a different direction than the triple tree. Im looking into all sorts of options right now and am currently researching the concours 1000 front forks. My fallback are some kz1100 front forks which are nearby and cheap. It's an obsession
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • rickysnicker
  • rickysnicker's Avatar
  • Away
05 Jun 2026 06:26
#924619
Having broken my collar bone twice, im looking at your gray and wondering why the doctor does not do surgery on it.  It appears there is a small piece of bone broken off and floating, not attached to anything.   Is the doctor thinking it will knit together?  Mine looked similar and I had to have a plate installed.
  • bound
05 Jun 2026 06:40
#924620
I know!!! I saw the xray and thought for sure that I would need surgery, but the doctor talked me through it and explained that the bone didn't break vertically but horizontally. On the xray you can see that they took the shot at a 20 degree angle. They described that the bone should heal the way it is as a big lump but if I feel it sticking out of my skin then I may need to go back in and get surgery. I mean, I really dont want to get surgery if I dont have to. Im not a doctor so I won't question it
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
05 Jun 2026 07:11
#924621
You have every right to challenge, it's an unfortunate fact of life that often treatment plans are dictated on a commercial basis rather than what's best for you
The following user(s) said Thank You: Nebr_Rex, bound
  • rickysnicker
  • Away
06 Jun 2026 05:32
#924644
Yes, understood, nor am I a doctor.  I was asking only from my own experience.   I sure hope it heals correctly and that side isn't shorter due to the knitting process, hopefully that affected shoulder won't allow hang considerably lower either.
  • H1Vindicator
  • H1Vindicator's Avatar
06 Jun 2026 06:15
#924646
Anything I do with regards to forks will be basically the whole front end....
In addition to the csr having leading axle forks. the steering head angle is another consideration. also. check the steering stop to see if it's bent. might give a clue as to how much force the steering head and frame sustained.
  • bound
06 Jun 2026 06:41
#924648
I appreciate your perspective! I hope it heals correctly too. I personally know the doctor who is treating me so im confident in their ability to consider my interests. Im fairly blind to the process of broken bones so im just listening to what she says so I heal the fastest. Ive already got a couple bandages off cause they dont hurt and aren't oozing anymore!
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
The following user(s) said Thank You: rickysnicker
