If a part has the same number but is from a different bike, will it fit my bike?
- KZLover82
22 Apr 2026 12:46
I have an 82 LTD1000 and it needs front reflectors, Part number 28012-1009, I got the part number from Partzilla from two different agents, so I hope it's correct. I have been searching and I keep coming up with reflectors for the Vulcan with this same part number. Will they fit my bike and does Kawasaki ever reuse part numbers for parts that are not identical?
Thanks
Thanks
Re: If a part has the same number but is from a different bike, will it fit my bike?
22 Apr 2026 18:40
Welcome to KZRider
Before you can post a 2nd post here you must post a introduction in our New Members forum
Site Moderator
Site Moderator
The following user(s) said Thank You: KZLover82
22 Apr 2026 23:54
Welcome from the UK. Manufacturers often use common parts across several models so yes, if the part number is right the part will be right. It isn't cost effective to make every part of every model bespoke.
The following user(s) said Thank You: slmjim+Z1BEBE, KZLover82
- slmjim+Z1BEBE
23 Apr 2026 04:52That's exactly right.Welcome from the UK. Manufacturers often use common parts across several models so yes, if the part number is right the part will be right. It isn't cost effective to make every part of every model bespoke.
In decades past when it was most common, the motorcycling print press often referred to new models that used existing parts from earlier models as 'parts bin bikes'.
Welcome to our little Interwebs corner of Motorcycle Madness, KZLover82.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Wookie58, KZLover82
