KZ Motors. How many series?
- KZQ
- Administrator
20 Jun 2025 06:46
Morning Folks,
I've been riding my 1100 Spectre these last two years and I suppose I've known it has a "J" motor in it. What I don't know is what makes a J motor different than the motor in my KZ 900.
I've known of a few Kawasaki KZ motor series, including the twins KZ 400, KZ 440 and the largest twin the KZ750.
I know of the four cylinder series starting from the KZ550 up through the KZ650 and finishing with the KZ 750.
Seems like the KZ 900 is closely related to the KZ1000's.
Just how many motor series exist in the KZ line?
Thanks in Advance !
Bill/KZQ
Thanks in Advance !
Bill/KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- asphalt900
Re: KZ Motors. How many series?
20 Jun 2025 06:52
J engine went thru several iterations. Component/external coloring etc. Reasoning?
The following user(s) said Thank You: KZQ, Gdizard
20 Jun 2025 08:20
Original 900, which became 1000, evolved into 1000 MKII, and eventually the J series (1000, 1100). Offshoot: shaft drive variants, 1000 and 1100. Cop bikes continued until after 2000. A LONG life.
KZ650 was next. Evolved into the bored out 750, with (minor) updated internals. Further improvements, with things like a bath tube head, shaft drive, followed. Zephyr, ZX7 variants after that. Again, a LONG life.
KZ400/500/550 (4 cylinder) was yet another series. More Zephyrs. A good long life with this family here, but not as long as the other two.
KZ750 Twin.
KZ400/440 Twin. Less changes than the 4 cylinder bikes.
Small bore KZ's also existed. 305, 250, 300? Not sure.
KZ750 Twin.
20 Jun 2025 08:36
Here is a very basic description of the different KZ1000 engines.
www.aperaceparts.com/tech/techkz1000.html
The following user(s) said Thank You: KZQ, Nessism, MFP-Joe, sf4t7
- Injected
20 Jun 2025 13:56
1978 KZ650B2 modified project
The following user(s) said Thank You: StreetfighterKz, KZQ, kimchella
- KZQ
- Administrator
20 Jun 2025 16:44Do these three twins constitute a series? Do the 440 and the 400 also spin backwards?KZ750 Twin. KZ400/440 Twin.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
20 Jun 2025 17:49There isn't much shared between the 400 and 750 engines, other than two cylinders. I don't know about the 400 rotation direction. I've always felt that the 400 bikes copied a lot of elements off the Honda twins of the late '60's and early '70's.Do these three twins constitute a series? Do the 440 and the 400 also spin backwards?KZ750 Twin. KZ400/440 Twin.
Bill
- DOHC
- Those Doe-Hawks really go!
20 Jun 2025 21:23KZQ post=913901 userid=1568
Speaking specifically about the "big four" engine history. The KZ900 and 1000 engines from 1973 to 1980 are basically all the same design. Of course Kawasaki made a whole series of running changes every year or two, some small and some substantial, but each change was an incremental update and nearly any part can interchange between any year.
I believe the cylinder head casting was functionally the same over the whole run. A lot of parts were made stronger (and heavier). The crankshaft got heavier between the 900 and 1000, and chaged again for the Mk2.
The 79-80 MK2 engine had modified castings for the crank case (extra ribs) and head (added clean air ports), and a stronger crank, and I've read it had thicker engine covers to reduce noise. But the parts are all still interchangable if you take enough of the new/old parts together (head and valve cover if using the larger cam sprockets, or the crank and generator cover and new stator/rotor, like that)
But the J engine for 1981 was basically a brand new design. It's not the same engine at all. It's a newly designed engine that happens to share most of the same internal dimensions with the old engine. So it's possible to swap the transmission, or the head, with some work. But those specific parts, and basically every other part, was redesigned from scratch for the J motor.
The cylinder head casting is completely different, and then different again for the bathtub GPZ1100. The cam chain system is different. The transmission is different. The crank case and frame mounting points are totally different. It's a whole new design.
The Ford Cleveland and Windsor V8 are totally different designs, but I read they put Cleveland heads on a Windsor block to make the Boss 302. That seems like a good example of how the Z1 and J motor are related.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: KZQ, slmjim+Z1BEBE, Nessism, sf4t7, Wookie58
- KZQ
- Administrator
27 Nov 2025 08:24 - 27 Nov 2025 08:26
Since I've been using my Spectre (KZ1100-D1) as my daily rider, these last two years I've been impressed by it's brute torque and it's smoothness at speed.
I've always read and believed that every bevel gear set costs 15 % to 20 % in lost power when compared to a chain or belt. Meaning that with a transverse crank the change of drive rotation occurs twice with the commensurate 30 to 40 % losses in power.
30 to 40 % can't be real else the chain drive KZ1100-A2 must be the rippinest KZ out there. Perhaps it is, along with the GPZ1100. Even so I doubt that the 15 to 20% loss estimate is accurate.
I've been looking around for a KZ1100-A2 to compare. They seem to be less available than the shaft drive 1100s.
I actually NEED one.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 27 Nov 2025 08:26 by KZQ.
27 Nov 2025 09:02I think these "sweeping" percentages for power loss are misleading, ultimately it will be effected by many factors like the weight of drivetrain components and the resulting inertia, oil weight in the transfer housings etc, etc, etc. Will definitely be significantly more than a chain but how much I believe will vary from machine to machine. In the car world for example an A/C compressor will take approx 3hp to drive it, an alternator between 1-3hp dependent on output. The losses are fixed regardless of engine output so would need to be calculated as a "percentage" for each individual application.Since I've been using my Spectre (KZ1100-D1) as my daily rider, these last two years I've been impressed by it's brute torque and it's smoothness at speed.
Bill
- KZQ
- Administrator
27 Nov 2025 09:13
Hi Wookie,
Except for the oil required to keep the gears lubed I hadn't imagined loads beyond the wiping of the gears and the preload on the pinion as being additional loads to the system, shaft verses chains.
I agree my percentages must be too sweeping to be realistic.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
