Fine words for the Z1
- blipco
- 2002 KZ1000P
25 May 2023 05:59
If you’re an enthusiast for the Z1 this short article is worth the read.
exhaustnotes.us/blog/index.php/2020/09/1...975-kawasaki-z1-900/
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7, howardhb
- sf4t7
Re: Fine words for the Z1
25 May 2023 10:26
Great article. That pretty much explains our obsession with the Z1's and KZ's.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- blipco
- 2002 KZ1000P
25 May 2023 12:45
Exhaust Notes is a cool site with great topics and writing.
Joe Gresh perfectly described old school power delivery.
25 May 2023 19:07 - 25 May 2023 19:09
"The big long cushy seat is a marvel of comfort."
AHAHAHAHAHAHA!!! About as comfortable as sitting on a slab of 3/4 inch plywood! My Z1 is a great ride....for about a half hour. Handling wise I prefer my KZ1000 LTD.
Last edit: 25 May 2023 19:09 by hardrockminer.
- sf4t7
26 May 2023 05:44
I think 3/4 plywood is what they used instead of foam inside the seat
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: hardrockminer
- blipco
- 2002 KZ1000P
26 May 2023 06:31
I never have a problem with factory seats, even on hours long rides, though many complain about the same seat.
I also ride a bicycle so the way I see it, if I can spend all day on a seat the size of my hand, by comparison, a motorcycle seat is like sitting on a sofa.
26 May 2023 06:46 - 26 May 2023 07:10I guess at least after a day in the saddle of your motorcycle you don't need to massage "nut butter" into your delicate partsI never have a problem with factory seats, even on hours long rides, though many complain about the same seat.
Last edit: 26 May 2023 07:10 by Wookie58.
The following user(s) said Thank You: blipco, MLMG
- blipco
- 2002 KZ1000P
26 May 2023 11:28
Wookie, that stuff looks good. I guess any excuse for a good rub will do
- willemZ900
- Z1B 4 ever
26 May 2023 12:50
My first holidy on the the Z was from the Netherlands to Italy. We (my girlfriend and me) have an sheepskin on the buddyseat and that worked pretty well
26 May 2023 16:08So do you spread it on your nuts???I guess at least after a day in the saddle of your motorcycle you don't need to massage "nut butter" into your delicate partsI never have a problem with factory seats, even on hours long rides, though many complain about the same seat.
- sf4t7
26 May 2023 19:33
Do they sell it at the same store that carries turd polish?
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
27 May 2023 00:44indeed you do, still I'm not surprised if you had been sitting on this all day. "Improved comfort"So do you spread it on your nuts???I guess at least after a day in the saddle of your motorcycle you don't need to massage "nut butter" into your delicate partsI never have a problem with factory seats, even on hours long rides, though many complain about the same seat.
