figuring numbers with shims and clarification
- Gdailey2112
- 82 KZ1100D1
24 Aug 2022 09:35
if an intake valve has .06mm clearance with 2.45mm shim
2.40mm shim would bring .06mm up to .11mm?
just looking for clarification that's all
thanx in adv
thanx in adv
1982 KZ1100D1
- Warren3200gt
Re: figuring numbers with shims and clarification
24 Aug 2022 09:52
Yep, thinner shim = bigger gap
- Gdailey2112
- 82 KZ1100D1
24 Aug 2022 14:54
thank you, Warren!! Am I doing the math correctly though? each step with shim size = .05mm ??
1982 KZ1100D1
25 Aug 2022 04:18
You are doing the math correctly. A thinner shim will provide more clearance. The number on the shim indicates the thickness in 1/100 of millimeters. As a caution, use OEM shims. I have seen incorrect numbers on repro shims.
