1975 KZ400 VIN Location
  • philcomo
  • philcomo's Avatar Topic Author
07 Nov 2021 10:22
#857584
I have found serial numbers on my 1975 KZ400.   Can anyone advise where the VIN is located?  Thanks!!!
  • TexasKZ
  • TexasKZ's Avatar
Re: 1975 KZ400 VIN Location
07 Nov 2021 13:09 - 07 Nov 2021 13:12
#857599
It is stamped into the steering head. There should be a white sticker next to the stamped number. The sticker should have the frame number plus the date of manufacture. The engine also has a number, but there is almost zero chance that it is the same as the frame number. Be aware that the modern 17-digit vin did not come into use until the early 1980s.
If you are curious about the numbers, here is some info you might find useful.
www.kzrider.com/filebase?task=download.s...id=1178&catid=64&m=0
Last edit: 07 Nov 2021 13:12 by TexasKZ.
The following user(s) said Thank You: philcomo
