76 KZ 750 B Twin issues
  • Shade2k76
  • Shade2k76's Avatar Topic Author
  • Banned
  • Banned
Re: 76 KZ 750 B Twin issues
04 Jul 2021 12:59
#851256
brand new battery (had about 4 days) had it on the tender last night.
bike off, 12.8
bike on, 12.6
ignition, 12.3
  • Mikaw
  • Mikaw's Avatar
04 Jul 2021 13:05
#851257
bike off, 12.8
bike on, 12.6
ignition, 12.3
Good. Trying to rule out items.
Have you tested voltage at the coil primary. Most bikes it a red/yellow. Not sure on yours. It needs to be close to battery voltage.
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 13:07
#851259
coil is good.  (just replaced a bad coil, and then bad plug boot due to ohms not reading right.
voltage through the coils reading on spec as well.
  • Mikaw
  • Mikaw's Avatar
04 Jul 2021 13:22
#851262
Great. General things to check.
  1. plug condition? ​​​​​​
  2. when it’s running any blue smoke? Oil burning?
  3. Fuel filter clean and gravity type?
  4. fresh fuel?
  5. Engine and battery have good clean ground?
  6. float levels in the carbs set?
  7. carb holder boots soft, no cracks and hose clamps tight?
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 13:26
#851263
plug condition is new
black smoke when choking out, at 3.5k rpm
filers are clean (added inline when first started build), yes,  gravity fed.
fresh fuel Premium
good clean ground
one is kind of stiff, but still flexable, second soft,  no holes or cacks, clamps tight and secure.
  • Mikaw
  • Mikaw's Avatar
04 Jul 2021 13:38 - 04 Jul 2021 13:40
#851264
Please describe how it or it does not run at 3.5k. You mentioned black smoke when it “choking out” at 3.5k. That’s an indication of overly rich.
EDIT, is it possible vibration is causing the choke lever to move to the on position?
Last edit: 04 Jul 2021 13:40 by Mikaw.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
04 Jul 2021 13:55
#851265
Is it possible that the main jets ( #45 in the crappy quality diagram) are missing?
www.partzilla.com/catalog/kawasaki/motor...etors-kz750-b1-b2-b3
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 14:07
#851267
I will indeed have to check, but I am pretty sure they are present and accounted for.
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 14:08
#851268
will try to get a video in a few minutes.  The choke is not moving back up to On.
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 14:17 - 04 Jul 2021 14:47
#851269
It is not THICK black smoke,  can almost see in video, but can hear what happens when I go on the throttle...
art-innovate.com/bike/video-2.mp4
Last edit: 04 Jul 2021 14:47 by Shade2k76.
  • Mikaw
  • Mikaw's Avatar
04 Jul 2021 14:38 - 04 Jul 2021 14:38
#851271
I think you re-posted a previous video. It’s on of the points and appears to be at idle.
Last edit: 04 Jul 2021 14:38 by Mikaw.
  • Shade2k76
  • Banned
  • Banned
04 Jul 2021 14:39
#851272
I do apologize for that....
try this one...    art-innovate.com/bike/video-3.mp4
