76 KZ 750 B Twin issues
- Shade2k76
- Banned
Re: 76 KZ 750 B Twin issues
04 Jul 2021 12:59
brand new battery (had about 4 days) had it on the tender last night.
bike off, 12.8
bike on, 12.6
ignition, 12.3
bike off, 12.8
bike on, 12.6
ignition, 12.3
04 Jul 2021 13:05Good. Trying to rule out items.brand new battery (had about 4 days) had it on the tender last night.
bike off, 12.8
bike on, 12.6
ignition, 12.3
Have you tested voltage at the coil primary. Most bikes it a red/yellow. Not sure on yours. It needs to be close to battery voltage.
- Shade2k76
- Banned
04 Jul 2021 13:07
coil is good. (just replaced a bad coil, and then bad plug boot due to ohms not reading right.
voltage through the coils reading on spec as well.
04 Jul 2021 13:22
Great. General things to check.
- plug condition?
- when it’s running any blue smoke? Oil burning?
- Fuel filter clean and gravity type?
- fresh fuel?
- Engine and battery have good clean ground?
- float levels in the carbs set?
- carb holder boots soft, no cracks and hose clamps tight?
- Shade2k76
- Banned
04 Jul 2021 13:26
plug condition is new
black smoke when choking out, at 3.5k rpm
filers are clean (added inline when first started build), yes, gravity fed.
fresh fuel Premium
good clean ground
one is kind of stiff, but still flexable, second soft, no holes or cacks, clamps tight and secure.
fresh fuel Premium
good clean ground
04 Jul 2021 13:38 - 04 Jul 2021 13:40
Please describe how it or it does not run at 3.5k. You mentioned black smoke when it “choking out” at 3.5k. That’s an indication of overly rich.
EDIT, is it possible vibration is causing the choke lever to move to the on position?
Last edit: 04 Jul 2021 13:40 by Mikaw.
04 Jul 2021 13:55
Is it possible that the main jets ( #45 in the crappy quality diagram) are missing?
www.partzilla.com/catalog/kawasaki/motor...etors-kz750-b1-b2-b3
- Shade2k76
- Banned
04 Jul 2021 14:07I will indeed have to check, but I am pretty sure they are present and accounted for.Is it possible that the main jets ( #45 in the crappy quality diagram) are missing?
- Shade2k76
- Banned
04 Jul 2021 14:08will try to get a video in a few minutes. The choke is not moving back up to On.Please describe how it or it does not run at 3.5k. You mentioned black smoke when it “choking out” at 3.5k. That’s an indication of overly rich.
- Shade2k76
- Banned
04 Jul 2021 14:17 - 04 Jul 2021 14:47It is not THICK black smoke, can almost see in video, but can hear what happens when I go on the throttle...will try to get a video in a few minutes. The choke is not moving back up to On.Please describe how it or it does not run at 3.5k. You mentioned black smoke when it “choking out” at 3.5k. That’s an indication of overly rich.
art-innovate.com/bike/video-2.mp4
Last edit: 04 Jul 2021 14:47 by Shade2k76.
04 Jul 2021 14:38 - 04 Jul 2021 14:38
I think you re-posted a previous video. It’s on of the points and appears to be at idle.
Last edit: 04 Jul 2021 14:38 by Mikaw.
- Shade2k76
- Banned
04 Jul 2021 14:39Please Log in or Create an account to join the conversation.
