Help ID 3 wheels please?
- slmjim+Z1BEBE
05 May 2021 20:21 - 06 May 2021 04:58
Wheel 1.Only marking is an 'M' inside a circle. Bearing holders are removable. Paper taped to tire reads "1976 KZ900". Morris Mag?
Wheel 2.'Kawasaki' is cast in.
Wheel 3.'Kawasaki' is cast in.
Thank You.
Good Ridin'
slmjim & Z1BEBE
Thank You.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 06 May 2021 04:58 by slmjim+Z1BEBE. Reason: Better detail pic
Re: Help ID 3 wheels please?
05 May 2021 20:29 - 05 May 2021 20:32
Wheel 1 is a 1976 Kz900 LTD Morris front. Wheel 2 ? Z1R. Wheel 3 appears the be a 1977-80 rear LTD Enkei mag.
Last edit: 05 May 2021 20:32 by Mikaw.
The following user(s) said Thank You: slmjim+Z1BEBE
- DOHC
- Those Doe-Hawks really go!
06 May 2021 06:21I agree with 1 and 3.Wheel 1 is a 1976 Kz900 LTD Morris front. Wheel 2 ? Z1R. Wheel 3 appears the be a 1977-80 rear LTD Enkei mag.
It looks like #2 is a 19" wheel, which would make it a matching set with #3. I believe the 77-80 LTD should have Enkei Kawasaki mags, 19" front and 16" rear. The '79-'80 MkII and '80 Z1R also had 19" front Enkei Kawasaki mags which I think were basically the same.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
06 May 2021 07:05DOHC, you might be right on #2. What thru me off was the valve stem location. On my 1978 Kz1000 LTD rear wheel the valve stem is equal distance from the spokes. I assumed the front would be the same, until I looked thru photos and found one of my front wheel. The valve stem is offset toward one spoke. I’m thinking DOHC is correct and #2 is the front match to #3I agree with 1 and 3.Wheel 1 is a 1976 Kz900 LTD Morris front. Wheel 2 ? Z1R. Wheel 3 appears the be a 1977-80 rear LTD Enkei mag.
