Verification of z1 900
- Harbacek
06 Feb 2021 14:51
undefined undefined Hi l am looking at purchasing a 1976 Kawasaki Z900 how do l tell the difference from an Aussie delivered to a imported model?
I do have the vin no and engine no
- Mc Tavish
Re: Verification of z1 900
06 Feb 2021 15:52 - 07 Feb 2021 03:49
The VIN sticker will have "Complies with Australian Standards" and Made in Japan Written on it.
It will have month and year of manufacture and the speedo will be Kmh.
Edit, thinking about it more, It's more than likely the VIN will be an aluminium tag riveted to the headstock as per ADR.
HMR is correct that Aust delivered bikes were z900.
1978 z650C
Last edit: 07 Feb 2021 03:49 by Mc Tavish.
06 Feb 2021 16:04 - 06 Feb 2021 16:04
The rear fender will be noticeably longer with a round red reflector. And will have dual front disc.
Last edit: 06 Feb 2021 16:04 by Mikaw.
06 Feb 2021 19:37
The answer for the general case is that you cannot tell from the engine or frame serial number. There are however some telltale signs to indicate if it's imported. North American models had KZ900 badges and a speedometer in MPH. The LTD model was only made in North America and the frame serial number began with a 5. European models had a longer rear fender. There are probably other differences that I haven't thought of.
What is your frame serial number?
07 Feb 2021 10:55
The front headlight will not be a sealed beam. It will have a removable bulb held in with a retainer. Aslo there will be a daytime running light in the headlight carrier and it is replaceable.
