Spoked Wheels
  • SyqBoi
  • SyqBoi's Avatar Topic Author
Spoked Wheels
17 Oct 2020 21:29
#837111
I have a 1983 KZ550 that I have built into a Bobber/ Chopper. I would like to replace the stock Mag style wheels wheels with Spoke style wheels. Ideally a 21” front with 15”-16” rear to replace the 19” front and the 18” rear that comes stock. I don’t want to spend a lot of money. It’s a cosmetic upgrade and being that it’s a 550, I’m probably going to outgrow it quick. I’ve been looking at used rms on Craigslist and Facebook, but how do I know which rims/ wheels will fit my current set up.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Spoked Wheels
18 Oct 2020 09:30
#837142
First thing is to mske sure the axle diameters are the same. Usually just playing with spacers and washers after that.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Nerdy
  • Nerdy's Avatar
  • Away
Re: Spoked Wheels
18 Oct 2020 10:29
#837151
It's a cosmetic change - not sure if it will be an upgrade. :unsure:
Even if you successfully swap the wheels, the handling will be compromised - since the geometry will be off - and the speedo (and thus the odo) will be off. If/when you sell it you will have to state that the mileage on the odo is not the true mileage. (If the title says that already then NBD)
You will need to change the front and/or rear sprocket(s) as well: the small rear wheel will have the effect of gearing the bike down, so with the current sprocket tooth counts you will need higher revs to maintain speed. (Don't replace just one sprocket: if the chain and sprockets are more than a couple months old, replace them as a set.)
Have you thought about the brakes?
And unless you're wringing all the performance out of the bike all the time, you're unlikely to "outgrow" a 550 immediately.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • martin_csr
  • martin_csr's Avatar
Re: Spoked Wheels
18 Oct 2020 13:55 - 18 Oct 2020 13:55
#837179
Probably the closest match would be the wheels from an 81-82 KZ650-CSR & they're probably a direct swap. 19" Fr & 16" Rr w drum brake. I installed the cast alloy wheels from a 1980 KZ550-Ltd >> all I needed were the wheels & Fr brake disk. everything else swapped. So I would guess the swap would work the other way, putting the CSR wheels & Fr Br disk on a 550.
Last edit: 18 Oct 2020 13:55 by martin_csr.
